TAB Key Progession Blocked by drop down lists?
Closed, InvalidPublic
I am using Blender 2.53 SVN 31739.
I noticed that when I click on the 3D Viewport Properties Panel > 3D Cursor Location fields and then use the TAB key to progress through the different fields in that panel, it gets stoped when it reaches the Lock To Object field.
Attached is picture with the mouse pointer indicating the field which stop TAB progression.
I realize this is probably not an actual bug, but was told to add this so it would probably get moved to the TODO list, if there is an official place to post this type of stuff let me know.
Indeed this is a nice item for the todo on our wiki regarding autocompletion. Nice to have unified throughout the entire application: http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/UserInterface#UI_Widgets
Nathan Letwory (jesterking) changed the task status from Unknown Status to Invalid.Sep 7 2010, 10:36 PM
Going through old UI ToDo tasks - this seems to have improved now. "Tab"-ing into the search field will now open the search box, so you can select an item with the arrow keys.
Marking the ToDo item as done.
