Audio Problem
Closed, InvalidPublic
HELP! when i put audio to my animation then try to scrub it, it crashed. my setting is in mpeg4, audio: mp3, playback is: auto scrubbing.I tried mpeg then encoding to flv, audio: mp3 or mp2 but still when i try to scrub blender will crash.
what's wrong? what should the setting be?
Hi,
We can't give user support here, this is a tracker for bug reports. If you can provide us with a .blend file and the audio file we can check your issue.
Please read the bug reporting guidelines! We need real information from you:
http://projects.blender.org/tracker/?func=add&group_id=9&atid=498
Hello sir,
Sorry, I wasnt able to read thte guidline, silly me, hehehe..
Anyway, I hope this helps
OS version: UBUNTU 9.10
Kenel Linux 2.631-22-generic
GNOME 2.28.1
3D card type: Inno 3D 90500
Blender version: 2.55 Beta
Own compiled versions: include svn version number from splash screen. : Blender 2.55.0
r33266
**i already solved the audio problem but this time it has problem during playblast.
example:
Settings:
OUTPUT: MPEG
ENCODING: FLASH
Error : Error initializing video stream
then Blender crashes but sometimes it wont crash.
I switch from MPEG to avi, H264 to flv or mpeg, etc
i get video stream or audio stream error.
Attached here are the blend file and print screens.
Assigned to Peter, he knows FFMPEG video/audio much better than I do.
What ffmpeg version did you use to build? Maybe there's a problem with the library. Did you try without audio?
Inactive report, not confirmed issue.
We are going to make official binaries available within 2 weeks. Please test these, and report back if there are issues?
Ton Roosendaal (ton) closed this task as Invalid.Dec 15 2010, 3:30 PM
