Metaball Select All function doesn't show (error)
When editing a metaball, in the header of the 3d-view, instead of showing a toggle select/deselect all in the select menu. There is just a grayed out error (or whatever you call it).
I was able to fix this fairly easily using this patch in blender/release/scripts/ui :
Index: space_view3d.py
--- space_view3d.py (revision 34050)
+++ space_view3d.py (working copy)
@@ -584,7 +584,7 @@
layout.separator()
- layout.operator("mball.select_deselect_all_metaelems")
+ layout.operator("mball.select_all").action = 'TOGGLE'
layout.operator("mball.select_inverse_metaelems")
layout.separator()
However maybe there is a better way to fix this (if so please let me know)
I attached the file, for convenience just in case.
This bug also causes a lot of other select options to not show.
And I was so exited I forgot my info:
2.56 r34061
Ubuntu Linux 32bit
Thanks, is a good fix. The old operator there wasn't even existing...
Ton Roosendaal (ton) closed this task as Resolved.Jan 4 2011, 2:11 PM
