This is a problem that i have with uv in python
As i sad in title we can´t make a new uv (MeshTextureFaceLayer) and return yours attributes in the same execution.
Trying this:
import bpy
obj = bpy.context.active_object
mesh = obj.data
uvtex = bpy.ops.mesh.uv_texture_add()
print(dir(uvtex))
we get the list:
['__and__', '__class__', '__contains__', '__delattr__', '__doc__', '__eq__', '__
format__', '__ge__', '__getattribute__', '__gt__', '__hash__', '__iand__', '__in
it__', '__ior__', '__isub__', '__iter__', '__ixor__', '__le__', '__len__', '__lt
__', '__ne__', '__new__', '__or__', '__rand__', '__reduce__', '__reduce_ex__', '
__repr__', '__ror__', '__rsub__', '__rxor__', '__setattr__', '__sizeof__', '__st
r__', '__sub__', '__subclasshook__', '__xor__', 'add', 'clear', 'copy', 'differe
nce', 'difference_update', 'discard', 'intersection', 'intersection_update', 'is
disjoint', 'issubset', 'issuperset', 'pop', 'remove', 'symmetric_difference', 's
ymmetric_difference_update', 'union', 'update']
but with the uv created and trying this:
import bpy
mesh = obj.data
uvtex = mesh.uv_textures.active
print(dir(uvtex))
we get this:
['__doc__', '__module__', '__slots__', 'active', 'active_clone', 'active_render'
, 'bl_rna', 'data', 'name', 'rna_type']
As would be...
This bug is crashing the script template "uv Operator" of Trunk
Any idea?
Bye!
Comment Actions
Operators never return data like this, we have rna functions which work as you are expecting.
most collections have load/new/add functions as well as equivalents for removing.
import bpy
uvlayer = obj.data.uv_textures.new()
