Two fail cases with modifiers targeting linked assets #26695
2 Participants
Reference: blender/blender#26695
%%%Attached are two blend files:
linked_asset: one object "Cube" and one object "Cubefoo", both in a group "linked_asset_group"
main_file: One relative-linked instance of "linked_asset_group" and one object "Cube" with a Shrinkwrap modifier with no target
In the modifier, when I try to select Cube in the Target dropdown, Blender rejects the selection. I note that the self object is not available in the dropdown, so this must be the linked Cube.
In the modifier, select "Cubefoo" for the target. (Hey, without the same name, it works! Hmm :) Save the file. Re-open the file. The target was not saved.
discovered with dobz r35747 win 64; confirmed with personal trunk win 32 r35906%%%
%%%3) With the modifier, target Cubefoo. In the viewport, rotate the linked_asset_group. The modifier does not respect Cubefoo's transform. Even if the linked_asset_group is placed under an empty in the scene and the empty is animated to rotate, the Cube stays put.%%%
%%%confirmed, investigating,%%%
%%%fixed issue #2, r35916
looking into #1 now.%%%
%%%#1, is a bug in that it shows an item which cant be used, but doubling up names in library items is generally not well supported, if you do this you will get troubles elsewhere too.
3, moving the dupli instance does not move the original objects in the group which its instancing.
closing.
