Objects not updated as they become visible in layers
Closed, InvalidPublic
I'm trying to find a serious bug (but too complex all at once) with point caches / smoke / shared actions and between scene links that causes animation to offset.
The effect of this bug is offsetted animation in some of the source object's
Since I don't know what is the culprit Ive prepared a simple blend with 3 objects:
all of them share the same action but are located in layer 1, 2 and 3
when frame changing with only one of the layers active and then selecting another layer you see how the object hasn't updated until you force a refresh
I suspect this has something to do with the bake all dynamics going nuts
Didn't check the file... but I do know that layer switching currently tries to do conservative changes only, to prevent it being slow.
Frame changes do work fine.
Depsgraph issue? Maybe janne can give a real verdict here.
rev 40164
Problem seems to have been fixed.
Blend doesn't show lack of UI update.
It's not fully fixed yet, how to redo:
* enable only second layer
* move one frame forward
* enable only first layer
This is a dependency graph issue with objects not getting updated as they become visible in a layer. Problem is that update tags from editing or frame changes are only set on objects on visible layers. Closed a duplicate of this bug here:
http://projects.blender.org/tracker/index.php?func=detail&aid=27446&group_id=9&atid=498
Closed issue caused by exactly the same issue -- http://projects.blender.org/tracker/?func=detail&aid=30176&group_id=9&atid=498
Added to the dependency graph todo list:
http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Animation#Dependency_Graph
Ton Roosendaal (ton) closed this task as Invalid.Mar 21 2012, 4:57 PM
