GLSL shader export patch #27524
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#27524
%%%This patch adds the python module 'gpu' to blender with one method in it:
export_shader(scene,material) to export the GLSL shader for use in an external
game engine.
The intention is to use this API in the X3D exporter to allow using the GLSL
shader unchanged in the H3D game engine. The function export everything that's
needed to use the shader.
Documentation in shader_export.txt
The patch modifies the GLSL library code by converting all 1D textures to 2D
textures for compatibility with X3D. To keep it small, the patch does not
include the modified
source/blender/gpu/intern/gpu_shader_material.glsl.c
You must run
release/datafiles/datatoc.py source/blender/gpu/intern/gpu_shader_material.glsl
after applying the patch to update the C version of the GLSL library.
The patch is also available for code review in http://codereview.appspot.com/4529098/
%%%Updated the patch to fix a minor typing error in the temporary GPUInputUniform structure: lamp field is an Object and not a Lamp datablock.
Added subscriber: @mont29
Is this patch still relevant/alive?
This patch has been integrated in trunk a long time ago in trunk. It's no long relevant as a patch.
Thanks Benoit, time to close then!
Added subscriber: @kevindietrich
So... closing! :)
