Python/Windows issue: "import uuid" results in an error popup #27666
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
9 Participants
Reference: blender/blender-addons#27666
%%%Reproduce:
I get a popup window stating:
R6034 An application has made an attempt to load the C runtime library incorrectly...
This popup occurs only on the very first attempt to load it.
Subsequent "import uuid" statements do not raise the error again.%%%
blender/blender#38966 was marked as duplicate of this issue
%%%Additional info: This error only occurs on Windows systems.
Linux and OSX do not suffer from this problem!
%%%This is very strange, it seems to be an MSVC dependancy issue.
Info I dug up on this issue:
http://bugs.python.org/issue4022
http://weblogs.asp.net/george_v_reilly/archive/2007/02/10/shell-extension-throwing-r6034-errors.aspx
Oddly enough it works in msvc2008 and msvc2010, on my windows XP system but 2.57b release and MinGW builds give the error.%%%
%%%I'm preparing a fix.%%%
%%%A fix in r37573.%%%
%%%closing. (if for some reason the fix isn't working reply and I'll re-open)%%%
%%%I just updated to revision 37604. Unfortunately i still get the exact same problem when i open the python console and then:
import uuid
I am on windows 7 and i used scons for building:
python scons/scons.py
%%%Make sure you don't have any runtime dlls in BF_INSTALLDIR, these will interfere with the fix.%%%
%%%I am building Blender with Visual c++ 2008 Express edition
and 32 bit python and using the following command:
Here is the list of libraries i have in the installation directory after
the build completes:
BlendThumb.dll
BlendThumb64.dll
OpenAL32.dll
SDL.dll
avcodec-52.dll
avdevice-52.dll
avformat-52.dll
avutil-50.dll
gnu_gettext.dll
iconv.dll
libpng.dll
libsndfile-1.dll
pthreadVC2.dll
python32.dll
swscale-0.dll
wrap_oal.dll
zlib.dll
The fix does still not work for me after completely rebuilding Blender:
After i open Blender, i go to the python console and:
import uuid
still gives me the error as initially reported.
I also tried to build for 64 bit. But i was not able to create a 64-bit Blender
based on my current setup. I also hesiotate to follow the "hack" described
on the Blender wiki, which is not even "officially supported by blebnder developers"
Maybe someone with a working 32-bit version can verify that the issue is not solved
for 32-bit builds.
%%%The uuid.py module in Python uses ctypes to get platform specific uuid creation routines (for performance benefits). So I think this is probably related to previous ctypes problems on Windows.
A workaround is to remove all the ctypes stuff from Python's uuid.py to avoid triggering the problem.%%%
Added subscriber: @MartijnBerger
python bug -> http://bugs.python.org/issue17213 (from terrachild in irc)
I think most simple solution is that we apply this work around
Changed status from 'Resolved' to: 'Open'
Added subscriber: @Wiz
Added subscribers: @sindra1961, @mont29
◀ Merged tasks: blender/blender#38966.
Current windows x64 msvc 2013 build does not suffer from this problem.
Can someone reconfirm this ?
It still occurs in windows XP/32bits msvc 2008.
Closing, with Python3.4x and MSVC2013 this is now resolved.
SHA-1: 9f16428cb5f047bf46bc338746a0fa84add6e720
We wont be using MSVC2008 for the official release.
Understood it; then I change the wording.
An error still occurs in blender-2.70-7660218-win32.zip for official release.
