Python docs about RenderEngine: importing properties_render Python module is incorrect #27740
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#27740
%%%This is about the example Python code on RenderEngine class documentation page: http://www.blender.org/documentation/blender_python_api_2_58_release/bpy.types.RenderEngine.html
Pasting the example code and trying to run (Alt+P) says that "properties_render" module is not found. The ending of the script should be replaced now with
bpy.types.RENDER_PT_render.COMPAT_ENGINES.add('custom_renderer')
bpy.types.MATERIAL_PT_preview.COMPAT_ENGINES.add('custom_renderer')
That is, no need to import any module, just access stuff through bpy.types. Attaching simple patch to doc/python_api/examples/bpy.types.RenderEngine.py that does it.
(Sidenote: first I had an idea for another workaround, by adding
import sys
sys.path.append('/scripts/startup/bl_ui/')
to the script. This makes the script execute but is still incorrect. This defines new RENDER_PT_render class, that isn't registered, and extending it's COMPAT_ENGINES doesn't do anything.)
The problem and solution tested with Blender 2.58, on Linux (Debian lenny (oldstable)), 32-bit.%%%
%%%fixed r38210.%%%
