rayCast() doesn't detect well a armature deformed mesh #28306
Reference: blender/blender#28306
Category: Physics
%%%If an object is deformed by an armature, this needs reinstancePhysicsMesh() to has physics updated data.
This data is used by rayCast() or rayCastTo(), but IT DOESN'T WORK WELL.
Start BGE in file and use Z and X keys to move the Cube. Approach it to the bending object center and see in Terminal when it tells wich object cast. %%%
%%%In the 12*.blend file, the object gets visible and invisible and more framerate of the script, to show the issue better.%%%
%%%Hi Mario, if you turn on "Show Physics Visualization" after you do reinstancePhysycsMesh() do you see the physics mesh changing?
As far as I know the Physics Mesh dont get updated , and that's about it.
A way to bypass this is using bone parenting to external objects. The external objects then collide with your environment as you need.%%%
%%%Yes, the physics change well, I didn't know about the Show Physics, so, I made an little cubes rain and all the cubes collide correctly with the deformed mesh. I think it is a rayCast() issue.
After reporting this, I made the same character with very simple objects, with no deforms, only parent to the armature and make them invisible at init.%%%
%%%I've attached a 13_ray_working.blend that appears to show things working as intended. Is there still a problem with the latest version of Blender?%%%
%%%Uploaded 14_ray_working.blend where the cube is moved a bit to the left (0.2 bu), and it stops disappearing. I don't know if it works better than before (I didn't realize it), but it still working wrong. Try using Z and X keys.
(I've modified the code, but I don't know why, I couldn't use the object property 'choca' to print debug, it doesn't appear in screen... another bug?)%%%
Added subscriber: @panzergame
@MarioSottile: Could you upload the blend file test ?
I found a file... but it is 12_ray_working.blend... and this reports says about 13_* and 14_*... that I don't have them.
I tested the file and it seems that the problem is still there... the cube that you move with Z and X is not hidden when it is behind the dynamically deformed object. Only when it gets very near to center, it is hidden.
