Property Editor hides properties #28333
Reference: blender/blender#28333
%%%Found in Blender 2.59
In some cases, the property editor does not show properties of an object because they are scrolled out of sight, yet there is no scrollbar, looking like there are no properties available at all.
This happens especially in Particle(with active PS) and Material context, because they regularly are much longer vertically, but in principle, this could happen in any context (e.g. when adding lots of Custom Properties). Probably this is also depending on available screen space/resolution, so if you can't get it to work on a 30" display, perhaps reducing vertical blender program window size makes the problem more likely to happen.%%%
%%%And by POS1 I mean "Home" on QWERTY keyboards.%%%
%%%This has been reported before... we realize it's awkward
The reason is that the scroll bar status is stored in the property view, to allow clicking around in UI and inspect values.
If we would reset the scrollbar on clicking objects without these properties, you'd need to scroll back to the bottom when you return to an object with (for example) particle properties again. People found that annoying too.
I can see both side arguments though, especially to show an empty view without scrollbar is ugly. Will check if this can be done more elegantly.%%%
%%%Sorry, I have not found a duplicate report with the search.
Assuming that the deletion of an object is the only way to trigger this bug: As some kind of a compromise, what about resetting the scrollbar when an object is deleted ? Since in this case the property editor is automatically changing to world context, it would be necessary to go back to the last context anyway, doing a second step to find the last position would not be such a big deal.
From a workflow point of view, I think that a deletion probably is the end of an activity that required access to the same properties on multiple objects, so it would not interfere with most users way of doing things.
Not so sure what to do if the context is pinned, though.%%%
%%%Deleting the object isn't the only way to reproduce this bug.
This could be marked and closed as a duplicate of this bug: http://projects.blender.org/tracker/index.php?func=detail&aid=24343&group_id=9&atid=498%%%
%%%closed as duplicate, will work on the other one.%%%
