Particle object type did not displayed
Closed, InvalidPublic
Duplicates: T31913
Particle render type object do not displayed in particle edit mode.
Just open attached file.
In the properties editor - particles - display tab - display bar (percent of displayed particles) - if you change this bar to 98% (or what ever you want) objects are will show till you rotate or zoom viewport.
Windows 7 Home Premium x32
- Renderer: ATI Radeon HD 4770
- Vendor: ATI Technologies Inc.
- Version: 3.3.11005 Compatibility Profile Context
Version: 2.59 (sub 4)
Revision: 40916
Confirmed on Ubuntu 11.04
It is not the only incorrect display with hair particles.
In Object Mode, if Path is selected in Properties Display panel; only Tips are visible.
In Particle Mode, if you try to hide hair particles; only Tips are hidden.
Ammm... maybe we should reassign this bug to active developer like Lukas Toenne?
Closing this duplicate of #31913.
Thomas Dinges (dingto) closed this task as Invalid.Sep 25 2012, 12:52 PM
