Node Normal does not work as expected since 2.60
In this simple Normal Node example setup you can see that the Normal Node doesn't function any more as expected since Blender version 2.60. To see the difference open an example blend file in Blender 2.59, press F12, and then render the same file in 2.60a. You can see the difference in an attached screenshot for comparison too.
Tested on Linux 32bit
Blender 2.59, 2.60, 2.60a and the latests svn.
Thank you.
Lukas, can you check this report as well? Thanks.
Your reported issue has been fixed in SVN. Thanks for taking the
time to report!.
Lukas Toenne (lukastoenne) closed this task as Resolved.Nov 6 2011, 4:40 PM
