Vertex/Edge/Face Select buttons shrink
Found in Blender 2.60a and r41872
With the default cube active, enter Edit mode and switch to Wireframe or Bounding Box shading modes. Now your Vertex/Edge/Face Select buttons are getting squashed horizontally, while the EditMode Button is growing larger. With Cycles enabled, Material and Rendered shading modes also cause this effect - Solid and Textured are fine.
Et ceterum censeo that bug #21516 http://projects.blender.org/tracker/?group_id=9&atid=498&func=detail&aid=21516 needs to be reopened - I've posted there but it seems that once a bug is closed, no one does get notified about new comments. Please tell me how to handle such issues in the future - I did not want to clutter the tracker by opening a new report.
Fix in svn, thanks for the report.
Regarding the other issue, usually after a few months it may be better to open a new report, whoever worked on the bug may not be keeping track of it anymore. In this case though, it's a todo item that is not considered a bug at the moment, since it's not a major issue and needs quite a bit of work to fix properly.
