Node lines are not drawing correct #29427
Reference: blender/blender#29427
%%%Hi Lukas,
as discussed, here is the report:
My specs
Ubuntu 64 bit
Intel I5
Intel i915 Graphics card
It happens in:
Newest build from trunk (r42189), but also in the official prerelease 2.61 version.
Description:
The lines between the nodes are not drawn correctly.
How to reproduce it:
Open the supplied blend - you should immediately see the missing lines (every node should be connected) - Compare the uploaded images (attaching or at the following positions)
Old revision on my card draws correctly:
http://www.pasteall.org/pic/show.php?id=21522
New revision on my card does not draw correctly:
http://www.pasteall.org/pic/show.php?id=21524
Generally, I'm able to reproduce it always, when I try to connect some nodes with a mix node to an output.
Greetings, Thomas%%%
%%%Everyone who has the same problem: Please comment here with your specs! We need more input on this!%%%
%%%Hi Lukas,
please take a look at the following code: This works flawlessly...let's talk about it on monday!
http://www.pasteall.org/26816/c
%%%I'd rather not remove the color progression along lines here ... It's not a crucial feature from a technical standpoint, but one that should work.
Sorry i can't give you a better solution, just can't reproduce it.%%%
%%%It looks like another inter driver bug, will leave the report on investigate to see if other people have the same trouble with that hardware.%%%
%%%Added a possible fix using GL_LINES instead of GL_LINE_STRIP for the shaded part, let me know if this works (node_line_draw_shaded.diff).%%%
%%%Lukas, that works! Ready for checkin :)%%%
%%%Campbell suggested it might work by enabling GL_BLEND. Should not be necessary either (no blending with background pixels required), but just out of curiosity can you test node_line_draw_shaded2.diff ?%%%
%%%Intel i5 64 bit ubuntu 11.10 - intels on processor graphics (hd?).
Start notice it already in 2.5x, in logic editor - but rarely and zooming in out solved it. Recently (in 2.60) visited the node editor and it was completely mad - most lines invisible and most of the rest only the drop-shadow. Came here to report and found this bug :-)%%%
%%%I've committed the fix for node line drawing (r42266).
@Lars: Could you make a second bug report about logic editor and include a screenshot and test file (even though i probably can't reproduce either)? Thanks!
I will also send a note to bf-committers mailing list about this.%%%
