External Numpad Issue. Press and hold to move the view in 3d #29436
Reference: blender/blender#29436
%%%I have this problem with my external Numpad, when i want to change the view in 3D view, i have to Press and Hold the buttons on the numpad to move the view, which makes it really difficult to navigate around.
There's no problem using the top numbers on the mac, when i press the "EMULATE NUMPAD" in the settings, but it's more comfortable to use the external numpad.
it works fine in blender 2.49, but not in the new versions. Ex 2.59 and 2.60
Other information, i'm using a Macbook pro and it's a Sandberg Usb numeric keyboard.
Also
When numlock is on- on the small number keyboard, the ZOOM IN key (numpad +) is the only button which works perfecly.
When i switch the Num lock button OFF, both Zoom buttons work perfectly (Numpad + and Numpad - )
and i can change keyframe up and down by pressing NUMPAD 4 and NUMPAD 6.
%%%This is a bit difficult to debug, since probably no developer has such an external numpad. With 2.5 we switched from Carbon to Cocoa, so it's likely related to that.
You could try running blender in debug mode and attach the results here (it will include the key press/release events). This can be done by running the following command in the terminal, from the folder where blender is located:
./blender.app/Contents/MacOS/blender -d%%%
%%%i hope you can use this for something :)
found bundled python: /Applications/blender-2.60a-release-OSX_10.6_x86_64/Blender/blender.app/Contents/MacOS/2.60/python
SRNA Subclassed: 'Context'
SRNA Subclassed: 'Operator'
SRNA Subclassed: 'Menu'
time bl_operators 0.0247
SRNA Subclassed: 'Panel'
SRNA Subclassed: 'Bone'
SRNA Subclassed: 'EditBone'
SRNA Subclassed: 'PoseBone'
SRNA Subclassed: 'Mesh'
SRNA Subclassed: 'Object'
SRNA Subclassed: 'Texture'
SRNA Subclassed: 'Header'
time bl_ui 0.0666
SRNA Subclassed: 'KeyingSetInfo'
time keyingsets_builtins 0.0057
addon_utils.enable io_anim_bvh
addon_utils.enable io_curve_svg
SRNA Subclassed: 'PropertyGroup'
addon_utils.enable io_mesh_ply
addon_utils.enable io_mesh_stl
addon_utils.enable io_mesh_uv_layout
addon_utils.enable io_scene_3ds
addon_utils.enable io_scene_fbx
addon_utils.enable io_scene_obj
addon_utils.enable io_scene_x3d
Python Script Load Time 0.1308
SRNA Subclassed: 'Group'
SRNA Subclassed: 'Library'
SRNA Subclassed: 'Macro'
SRNA Subclassed: 'MeshEdge'
SRNA Subclassed: 'MeshFace'
SRNA Subclassed: 'RenderEngine'
SRNA Subclassed: 'Sound'
SRNA Subclassed: 'Text'
read file
handle evt 0 win 0 op WM_OT_splash
swin 14 added
bpy.ops.wm.splash()
recalcob Cube
recalcdata Cube
set drawable 1
set screen
pass on evt 1 val 1
pass on evt 1 val 2
pass on evt 171 val 1
pass on evt 151 val 1
pass on evt 171 val 2
pass on evt 151 val 2
pass on evt 152 val 1
pass on evt 152 val 2
pass on evt 153 val 1
pass on evt 153 val 2
pass on evt 154 val 1
pass on evt 154 val 2
pass on evt 155 val 1
pass on evt 155 val 2
pass on evt 156 val 1
pass on evt 156 val 2
pass on evt 157 val 1
pass on evt 157 val 2
pass on evt 158 val 1
pass on evt 158 val 2
pass on evt 159 val 1
pass on evt 159 val 2
handle evt 151 win 13 op VIEW3D_OT_viewnumpad
bpy.ops.view3d.viewnumpad(type='FRONT', align_active=False)
pass on evt 274 val 0
handle evt 274 win 13 op VIEW3D_OT_smoothview
bpy.ops.view3d.smoothview()
handle evt 153 win 13 op VIEW3D_OT_viewnumpad
bpy.ops.view3d.viewnumpad(type='RIGHT', align_active=False)
handle evt 154 win 13 op VIEW3D_OT_view_orbit
bpy.ops.view3d.view_orbit(type='ORBITLEFT')
handle evt 156 win 13 op VIEW3D_OT_view_orbit
bpy.ops.view3d.view_orbit(type='ORBITRIGHT')
handle evt 157 win 13 op VIEW3D_OT_viewnumpad
bpy.ops.view3d.viewnumpad(type='TOP', align_active=False)
pass on evt 164 val 1
handle evt 164 win 13 op VIEW3D_OT_zoom
bpy.ops.view3d.zoom(delta=1, mx=575, my=416)
pass on evt 164 val 2
pass on evt 162 val 1
pass on evt 162 val 2
handle evt 162 win 13 op VIEW3D_OT_zoom
bpy.ops.view3d.zoom(delta=-1, mx=575, my=416)
Blender quit
Henrik-Groth-Hansens-MacBook-Pro:blender-2.60a-release-OSX_10.6_x86_64 Henrik$ %%%
%%%The debug output does tell us something, there's incoming events from an "unknown key" mixed in with the numpad keys. Committed a possible fix for this to svn, could you test the automated build to see if it's fixed?
http://builder.blender.org/download/%%%
%%%i downloaded the new build but couldnt open it. I get an error message from the mac :
Process: blender [30082]
Path: /Users/Henrik/Desktop/blender-2.60-r42367M-OSX-x86_64/blender.app/Contents/MacOS/blender
Identifier: org.blenderfoundation.blender
Version: 2.60 (2.60, 2011-Dec-03, Blender Foundation)
Code Type: X86-64 (Native)
Parent Process: launchd [205]
Date/Time: 2011-12-03 23:36:43.027 +0100
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 108035 sec
Crashes Since Last Report: 24
Per-App Crashes Since Last Report: 20
Anonymous UUID: B0538F5D-1492-435C-B21F-27C67BCE26D6
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Application Specific Information:
abort() called
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 libSystem.B.dylib 0x00007fff8886d0b6 __kill + 10
1 libSystem.B.dylib 0x00007fff8890d9f6 abort + 83
2 org.blenderfoundation.blender 0x0000000100c0ed3e __gnu_cxx::__verbose_terminate_handler() + 254
3 org.blenderfoundation.blender 0x0000000100c0d456 __cxxabiv1::__terminate(void (*)()) + 6
4 org.blenderfoundation.blender 0x0000000100c0c6ff __cxa_call_terminate + 47
5 org.blenderfoundation.blender 0x0000000100c0d035 __gxx_personality_v0 + 565
6 ??? 0x0000000103433648 0 + 4349703752
Thread 0 crashed with X86 Thread State (64-bit):
Binary Images:
0x100000000 - 0x102c08fff +org.blenderfoundation.blender 2.60 (2.60, 2011-Dec-03, Blender Foundation) /Users/Henrik/Desktop/blender-2.60-r42367M-OSX-x86_64/blender.app/Contents/MacOS/blender
0x104b16000 - 0x104b3efff com.apple.audio.OpenAL 1.4 (1.4) /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
0x104b4c000 - 0x104b60fef +libgcc_s.1.dylib ??? (???) <2B4AF617-05D9-372F-B932-513FDE8D143F> /Users/Henrik/Desktop/blender-2.60-r42367M-OSX-x86_64/blender.app/Contents/MacOS/lib/libgcc_s.1.dylib
0x7fff5fc00000 - 0x7fff5fc3bdef dyld 132.1 (???) /usr/lib/dyld
0x7fff80086000 - 0x7fff8008bfff libGFXShared.dylib ??? (???) <1D0D3531-9561-632C-D620-1A8652BEF5BC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff8008c000 - 0x7fff800d3ff7 com.apple.coreui 2 (114) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff800d4000 - 0x7fff800f4ff7 com.apple.DirectoryService.Framework 3.6 (621.11) /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff8035f000 - 0x7fff80365ff7 IOSurface ??? (???) <04EDCEDE-E36F-15F8-DC67-E61E149D2C9A> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff80366000 - 0x7fff8048eff7 com.apple.MediaToolbox 0.484.52 (484.52) /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff8048f000 - 0x7fff8050cfef libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <35ECA411-2C08-FD7D-11B1-1B7A04921A5C> /usr/lib/libstdc++.6.dylib
0x7fff8054c000 - 0x7fff80551ff7 com.apple.CommonPanels 1.2.4 (91) <4D84803B-BD06-D80E-15AE-EFBE43F93605> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff80566000 - 0x7fff80566ff7 com.apple.ApplicationServices 38 (38) <10A0B9E9-4988-03D4-FC56-DDE231A02C63> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff80571000 - 0x7fff80594fff com.apple.opencl 12.3.6 (12.3.6) <42FA5783-EB80-1168-4015-B8C68F55842F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff80595000 - 0x7fff806cafff com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff80f2b000 - 0x7fff80f53fff com.apple.DictionaryServices 1.1.2 (1.1.2) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff80f94000 - 0x7fff80fe3fef libTIFF.dylib ??? (???) <1E2593D1-A7F6-84C6-DF8F-0B46AE445926> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff81145000 - 0x7fff81303fff libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <4274FC73-A257-3A56-4293-5968F3428854> /usr/lib/libicucore.A.dylib
0x7fff8139b000 - 0x7fff814bafe7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <14115D29-432B-CF02-6B24-A60CC533A09E> /usr/lib/libcrypto.0.9.8.dylib
0x7fff814f6000 - 0x7fff81537fff com.apple.SystemConfiguration 1.10.8 (1.10.2) <78D48D27-A9C4-62CA-2803-D0BBED82855A> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff816d5000 - 0x7fff8170ffff libcups.2.dylib 2.8.0 (compatibility 2.0.0) <7982734A-B66B-44AA-DEEC-364D2C10009B> /usr/lib/libcups.2.dylib
0x7fff81710000 - 0x7fff81712fff com.apple.print.framework.Print 6.1 (237.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff81fac000 - 0x7fff8203cfff com.apple.SearchKit 1.3.0 (1.3.0) <4175DC31-1506-228A-08FD-C704AC9DF642> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff8204b000 - 0x7fff82072ff7 libJPEG.dylib ??? (???) <46A413EA-4FD1-A050-2EF0-6279F3EAD581> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff82073000 - 0x7fff82074fff liblangid.dylib ??? (???) /usr/lib/liblangid.dylib
0x7fff82075000 - 0x7fff82233ff7 com.apple.ImageIO.framework 3.0.4 (3.0.4) <0A4F51A1-4502-767B-8A4E-F14C6214EF88> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff8225c000 - 0x7fff822abff7 com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <01B370FB-D524-F660-3826-E85B7F0D85CD> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x7fff822ac000 - 0x7fff822f5fef libGLU.dylib ??? (???) <1C050088-4AB2-2BC2-62E6-C969F925A945> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff822f6000 - 0x7fff82304ff7 libkxld.dylib ??? (???) <8145A534-95CC-9F3C-B78B-AC9898F38C6F> /usr/lib/system/libkxld.dylib
0x7fff82305000 - 0x7fff8231cfff com.apple.ImageCapture 6.1 (6.1) <79AB2131-2A6C-F351-38A9-ED58B25534FD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff82329000 - 0x7fff82329ff7 com.apple.Carbon 150 (152) <19B37B7B-1594-AD0A-7F14-FA2F85AD7241> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff82332000 - 0x7fff82417fef com.apple.DesktopServices 1.5.11 (1.5.11) <39FAA3D2-6863-B5AB-AED9-92D878EA2438> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff83453000 - 0x7fff834a8ff7 com.apple.framework.familycontrols 2.0.2 (2020) /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x7fff83512000 - 0x7fff83515ff7 libCoreVMClient.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff83570000 - 0x7fff83586fe7 com.apple.MultitouchSupport.framework 207.11 (207.11) <8233CE71-6F8D-8B3C-A0E1-E123F6406163> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff83a25000 - 0x7fff83a25ff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff83a2b000 - 0x7fff83acbfff com.apple.LaunchServices 362.3 (362.3) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff83bd7000 - 0x7fff83c23fff libauto.dylib ??? (???) /usr/lib/libauto.dylib
0x7fff83c70000 - 0x7fff83cfcfef SecurityFoundation ??? (???) <6860DE26-0D42-D1E8-CD7C-5B42D78C1E1D> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff83cfd000 - 0x7fff83d12ff7 com.apple.LangAnalysis 1.6.6 (1.6.6) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff83e3d000 - 0x7fff83e4cfff com.apple.NetFS 3.2.2 (3.2.2) <7CCBD70E-BF31-A7A7-DB98-230687773145> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff83e4d000 - 0x7fff83fc4fe7 com.apple.CoreFoundation 6.6.5 (550.43) <31A1C118-AD96-0A11-8BDF-BD55B9940EDC> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff83fc5000 - 0x7fff83fd6ff7 libz.1.dylib 1.2.3 (compatibility 1.0.0) /usr/lib/libz.1.dylib
0x7fff83fd7000 - 0x7fff83fedfef libbsm.0.dylib ??? (???) <42D3023A-A1F7-4121-6417-FCC6B51B3E90> /usr/lib/libbsm.0.dylib
0x7fff83ff5000 - 0x7fff84010ff7 com.apple.openscripting 1.3.1 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff84433000 - 0x7fff8443eff7 com.apple.speech.recognition.framework 3.11.1 (3.11.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff8443f000 - 0x7fff8446aff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <8AB4CA9E-435A-33DA-7041-904BA7FA11D5> /usr/lib/libxslt.1.dylib
0x7fff8446b000 - 0x7fff844acfef com.apple.CoreMedia 0.484.52 (484.52) <3F868AF8-1089-10C3-DCEB-565690FD9742> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff844ad000 - 0x7fff845ebfff com.apple.CoreData 102.1 (251) <32233D4D-00B7-CE14-C881-6BF19FD05A03> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff846f7000 - 0x7fff84775ff7 com.apple.CoreText 151.10 (???) <54961997-55D8-DC0F-2634-674E452D5A8E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff84877000 - 0x7fff84878ff7 com.apple.TrustEvaluationAgent 1.1 (1) <51867586-1C71-AE37-EAAD-535A58DD3550> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff84879000 - 0x7fff849e9fff com.apple.QTKit 7.7 (1783) /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff849ea000 - 0x7fff84c73ff7 com.apple.security 6.1.2 (55002) <4419AFFC-DAE7-873E-6A7D-5C9A5A4497A6> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff84e90000 - 0x7fff84f6dfff com.apple.vImage 4.1 (4.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff84f6e000 - 0x7fff851f0fe7 com.apple.Foundation 6.6.7 (751.62) <6F2A5BBF-6990-D561-2928-AD61E94036D9> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff851f1000 - 0x7fff85205fff libGL.dylib ??? (???) <2ECE3B0F-39E1-3938-BF27-7205C6D0358B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff852a4000 - 0x7fff8530efe7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <75A8D840-4ACE-6560-0889-2AFB6BE08E59> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff8530f000 - 0x7fff85312fff com.apple.help 1.3.2 (41.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff854f2000 - 0x7fff857f0fff com.apple.HIToolbox 1.6.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff857f1000 - 0x7fff85851fe7 com.apple.framework.IOKit 2.0 (???) <4F071EF0-8260-01E9-C641-830E582FA416> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff85a45000 - 0x7fff85a54fef com.apple.opengl 1.6.13 (1.6.13) <516098B3-4517-8A55-64BB-195CDAA5334D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff85ad4000 - 0x7fff85aedfff com.apple.CFOpenDirectory 10.6 (10.6) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff85aee000 - 0x7fff85b5fff7 com.apple.AppleVAFramework 4.10.26 (4.10.26) <28C1B366-DF2B-111B-1863-0713B105D930> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff85bf5000 - 0x7fff85ca5fff edu.mit.Kerberos 6.5.11 (6.5.11) <085D80F5-C9DC-E252-C21B-03295E660C91> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff85ca6000 - 0x7fff85cb2fff libbz2.1.0.dylib 1.0.5 (compatibility 1.0.0) <6FB0A8F4-72A1-D28F-E801-DE2C7498AFB9> /usr/lib/libbz2.1.0.dylib
0x7fff85cb3000 - 0x7fff85d4dfe7 com.apple.ApplicationServices.ATS 275.16 (???) <4B70A2FC-1902-5F27-5C3B-5C78C283C6EA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff85d4e000 - 0x7fff85d55fff com.apple.OpenDirectory 10.6 (10.6) <4200CFB0-DBA1-62B8-7C7C-91446D89551F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff85f69000 - 0x7fff86061ff7 libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <7E4ADB5A-CC77-DCFD-3E54-2F35A2C8D95A> /usr/lib/libiconv.2.dylib
0x7fff86062000 - 0x7fff86a5cff7 com.apple.AppKit 6.6.8 (1038.36) <4CFBE04C-8FB3-B0EA-8DDB-7E7D10E9D251> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff86a5d000 - 0x7fff86ab0ff7 com.apple.HIServices 1.8.3 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff86ab1000 - 0x7fff86b36ff7 com.apple.print.framework.PrintCore 6.3 (312.7) <CDFE82DD-D811-A091-179F-6E76069B432D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff86b37000 - 0x7fff86b37ff7 com.apple.Cocoa 6.6 (???) <68B0BE46-6E24-C96F-B341-054CF9E8F3B6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff86b4e000 - 0x7fff86c0ffef com.apple.ColorSync 4.6.6 (4.6.6) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff86c10000 - 0x7fff86d27fef libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <1B27AFDD-DF87-2009-170E-C129E1572E8B> /usr/lib/libxml2.2.dylib
0x7fff86d28000 - 0x7fff8705cfef com.apple.CoreServices.CarbonCore 861.39 (861.39) <1386A24D-DD15-5903-057E-4A224FAF580B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff8710d000 - 0x7fff8712aff7 libPng.dylib ??? (???) <6D8E515B-E0A2-2BA1-9CAC-8CB8A8B35879> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff8712b000 - 0x7fff8712fff7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <95718673-FEEE-B6ED-B127-BCDBDB60D4E5> /usr/lib/system/libmathCommon.A.dylib
0x7fff87474000 - 0x7fff874affff com.apple.AE 496.5 (496.5) <208DF391-4DE6-81ED-C697-14A2930D1BC6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff874b0000 - 0x7fff878f3fef libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <0CC61C98-FF51-67B3-F3D8-C5E430C201A9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff87e68000 - 0x7fff87f1dfe7 com.apple.ink.framework 1.3.3 (107) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff87f1e000 - 0x7fff87fdbfff com.apple.CoreServices.OSServices 359.2 (359.2) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff87fdc000 - 0x7fff884e2ff7 com.apple.VideoToolbox 0.484.52 (484.52) /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff88591000 - 0x7fff885a5ff7 com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <621B7415-A0B9-07A7-F313-36BEEDD7B132> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff885a6000 - 0x7fff8867afe7 com.apple.CFNetwork 454.12.4 (454.12.4) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff8867b000 - 0x7fff88795fef libGLProgrammability.dylib ??? (???) <8A4B86E3-0FA7-8684-2EF2-C5F8079428DB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff88798000 - 0x7fff8879dfff libGIF.dylib ??? (???) <201B8077-B5CC-11AA-E1B0-1D057ABE416A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff8879e000 - 0x7fff8881dfe7 com.apple.audio.CoreAudio 3.2.6 (3.2.6) <79E256EB-43F1-C7AA-6436-124A4FFB02D0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff8881e000 - 0x7fff889dffef libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib
0x7fff889e0000 - 0x7fff88d7dfe7 com.apple.QuartzCore 1.6.3 (227.37) <16DFF6CD-EA58-CE62-A1D7-5F6CE3D066DD> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff88da3000 - 0x7fff895adfe7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff895b3000 - 0x7fff89674fff libFontParser.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff89749000 - 0x7fff897ffff7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <03140531-3B2D-1EBA-DA7F-E12CC8F63969> /usr/lib/libobjc.A.dylib
0x7fff89aa2000 - 0x7fff89aecff7 com.apple.Metadata 10.6.3 (507.15) <2EF19055-D7AE-4D77-E589-7B71B0BC1E59> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff89aed000 - 0x7fff89aedff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <2BB7D669-4B40-6A52-ADBD-DA4DB3BC0B1B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff89b51000 - 0x7fff8a24dff7 com.apple.CoreGraphics 1.545.0 (???) <58D597B1-EB3B-710E-0B8C-EC114D54E11B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff8a24e000 - 0x7fff8a26ffff libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <6993F348-428F-C97E-7A84-7BD2EDC46A62> /usr/lib/libresolv.9.dylib
0x7fff8a270000 - 0x7fff8a295ff7 com.apple.CoreVideo 1.6.2 (45.6) /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff8a298000 - 0x7fff8a298ff7 com.apple.CoreServices 44 (44) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff8a299000 - 0x7fff8a29fff7 com.apple.CommerceCore 1.0 (9.1) <3691E9BA-BCF4-98C7-EFEC-78DA6825004E> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x7fff8a2a0000 - 0x7fff8a2a6ff7 com.apple.DiskArbitration 2.3 (2.3) <857F6E43-1EF4-7D53-351B-10DE0A8F992A> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff8a2a7000 - 0x7fff8a2ecfff com.apple.CoreMediaIOServices 140.0 (1496) /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
0x7fff8a390000 - 0x7fff8a390ff7 com.apple.vecLib 3.6 (vecLib 3.6) <08D3D45D-908B-B86A-00BA-0F978D2702A7> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff8a391000 - 0x7fff8a392ff7 com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <53299948-2554-0F8F-7501-04B34E49F6CF> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff8a393000 - 0x7fff8a3a5fe7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <76B83C8D-8EFE-4467-0F75-275648AFED97> /usr/lib/libsasl2.2.dylib
0x7fff8a46c000 - 0x7fff8a46fff7 com.apple.securityhi 4.0 (36638) <38935851-09E4-DDAB-DB1D-30ADC39F7ED0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff8a4e9000 - 0x7fff8a531ff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <170DE04F-89AB-E295-0880-D69CAFBD7979> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff8a532000 - 0x7fff8a573fef com.apple.QD 3.36 (???) <5DC41E81-32C9-65B2-5528-B33E934D5BB4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff8a574000 - 0x7fff8a62dfff libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <2C5ED312-E646-9ADE-73A9-6199A2A43150> /usr/lib/libsqlite3.dylib
0x7fff8a62e000 - 0x7fff8a65ffff libGLImage.dylib ??? (???) <7F102A07-E4FB-9F52-B2F6-4E2D2383CA13> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff8a69e000 - 0x7fff8a6a0fff libRadiance.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fffffe00000 - 0x7fffffe01fff libSystem.B.dylib ??? (???) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib
Model: MacBookPro5,5, BootROM MBP55.00AC.B03, 2 processors, Intel Core 2 Duo, 2.26 GHz, 8 GB, SMC 1.47f2
Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M, PCI, 256 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.10.131.42.4)
Bluetooth: Version 2.4.5f3, 2 service, 12 devices, 2 incoming serial ports
Network Service: AirPort, AirPort, en1
Network Service: SyncMate PAN, Ethernet, en2
Serial ATA Device: Hitachi HTS545016B9SA02, 149,05 GB
Serial ATA Device: HL-DT-ST DVDRW GS23N
USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8507, 0x24400000 / 2
USB Device: Internal Memory Card Reader, 0x05ac (Apple Inc.), 0x8403, 0x26500000 / 2
USB Device: Apple Internal Keyboard / Trackpad, 0x05ac (Apple Inc.), 0x0237, 0x04600000 / 3
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0x04500000 / 2
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x06100000 / 2
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8213, 0x06110000 / 4
%%%Think build from http://download.blender.org/release/Blender2.61/ should work for you. Can you please test it?%%%
%%%Hi again. This versions seems to work. i can use the Numpad now as i'm used to.
Thank you:)%%%
%%%As i understand, numpad works as expected now, so closing report now. Feel free to poke me here if i miunderstand your comment :)
THanks for both of report and fix :)%%%
