Allows more direct editing of objects linked from library.blend files #29630
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
7 Participants
Reference: blender/blender-addons#29630
Project: Blender Extensions
Tracker: Py Scripts Contrib
Python: 3.2
Blender: 2.60
Author(s): Jason van Gumster (Fweeb)
Script name: Edit Linked Library
Wiki page: http://wiki.blender.org/index.php/Extensions:2.5/Py/Scripts/Object/Edit_Linked_Library
Category: Unstable (example)
Status: Open
%%%When working in larger projects that involve scenes with assets linked from a .blend library, it can get very time-consuming to save your current scene, track down the proper linked .blend, make your modifications, save, and return to your original scene file. This add-on allows you to accomplish this process with only a pair of mouse-clicks (one to get to the linked library and one to resume work on your scene).
Script works great for linked groups. Would be nice for future versions to support regularly linked objects as well as proxy-fied rigs in a linked group.%%%
This task was automatically closed as archived as part of migration, because it was determined to be no longer active.
The authoritative list of addons is on the wiki, we no longer have a report for each addon to track bugs and updates. Bugs can be reported individually and assigned to the addon developers. See the #Addons project page for more information on the workflow.
%%%Oops! Forgot to attach the script!%%%
%%%Ran into a little bug that occurred when a user opens a different .blend file before returning to the original. In that scenario, the "Return to Original File" button would remain stuck in the Toolshelf. I just updated the script to include a persistent load_post handler that checks to see if loaded file is part of the Edit Linked -> Return to Original loop. If it isn't , the global variables are reset to allow for a new session.%%%
%%%Updated script. Now it works with normally linked (not via dupligroup) objects.%%%
%%%Update to script (v 0.7.0):
%%%marking for contrib%%%
%%%Hi,
Due to changes to the api including the merging of bmesh, several addons are outdated.
Please, if you are the author of an addon check your script with blender revision 44256 or newer.
That is builds made After blender 2.62 official release.
I would ask that updates be made to your addon before the Blender 2.63 release.
6-8 weeks away.
This allows time for the api to become more exposed & bmesh to stablize furthur.
If you need help, drop into irc freenode #blenderpython or #blendercoders & feel welcome to ask questions.
At the time of 2.63 release, scripts that are not repaired or in active developement will have their tracker page marked "Closed"
this will not affect your links to the tracker, similar to closing scripts in 2.49b, the page will be still availible & can be re-opened.
Thanks for your understanding & patience during these Exciting Times.
Brendon.%%%
%%%You have been granted access to commit this addon into contrib.
if you have blenders source code checked out, this is accessed from:
./release/scripts/addons_contrib/
The SVN path is https://svn.blender.org/svnroot/bf-extensions/contrib/py/scripts/addons
You can checkout this path, or commit from the path in blenders source.
Please commit your script to this repository, This way it will be available in blender builds under the
Testing
section of our addons in all builds except for release.The username and password for SVN match the ones you use on this website.
To be included in release this needs to have a full review but first its best to commit to contrib which makes iterating on changes easier.
For login/account issues - the project admins directly:
Checklist - Don't Skip This!
For quick checklist of rules to follow for contributing see:
http://wiki.blender.org/index.php/Dev:Py/Sharing#Rules_for_SVN_Committers
Please join this mailing list before committing:
http://lists.blender.org/mailman/listinfo/bf-extensions-cvs
If you have general questions, mail the bf-python mailing list is good to be on also.
http://lists.blender.org/mailman/listinfo/bf-python
%%%I received error repeatedly in the CMD window when launching my most recent compiled version r47919, now posted on Graphicall.org.
I will inform T.K. because this only happens in the Freestyle branch that I have been compiling for Graphicall.org for years. I will leave a note for T.K. also.
Cursor monitor: launched
%%%hi,
error report:
http://imagebin.org/226329
looks same as above.%%%
%%%Moved from Py Scripts Upload to Py Scripts Contrib%%%
%%%moved page to contrib section
assigned to Fweeb%%%
%%%Hi, I'm glad this tool is back! I patched the script to have the filepath in a text property instead than as a label, it's a very easy change which I find very useful.
It's just about replacing the line
layout.label(text="Path: %s" %
with
layout.prop(context.active_object.dupli_group.library,
what do you think? Is it feasible to have this in the official version?%%%
%%%Hey
There seems to be a bug when you Link an object to a new file, and then you haven't saved and make blender open the file in the same Instance with Autosave on it wont and give you an error message, and of course if you turn it off, and then go to the linked file and try to come back to the unsaved file it wont since it wasn't saved and now that file is lost.
Maybe it should point to the autosaved file blender makes by default when you haven't just saved?%%%
