Patch for [#28298] Header/footer scroll resets itself upon many actions
Patch for: T28298
This patch:
Removes hack to completley reset headers regions in ED_area_initialize().
Adds check to adjust "cur" variable correctly when "align" is using V2D_ALIGN_NO_NEG_Y.
Changes UI_view2d_totRect_set function in the header drawing code to use "headery" variable.
If more info on the bug or why this patch works is needed, I can explain in detail.
Thanks, applied patch. Discussion in :
http://projects.blender.org/tracker/index.php?func=detail&aid=28298&group_id=9&atid=498
Ton Roosendaal (ton) closed this task as Resolved.Oct 25 2012, 2:45 PM
