XIM improvement (non-latin support + connection recovery) #30274
6 Participants
Reference: blender/blender#30274
%%%I implemented two features:
Currently it supports only "root window" style input, while most people (and I) want "over the spot" or "on the spot" style one. Probably the implementation of "over the spot" or "on the spot" style becomes much complicated, because XIM server requires the coordinates of current cursor location relative to the screen in order to show the candidate window in appropriate position.
Please check the patch.
%%%Tiny fix. New patch is XIM_non-latin_V2.patch.
In my setting of IBus, control+m is assigned to "commit string", but this key stroke didn't work in the text editor. For example, if I'm going to input a utf8 character "あ", typing control+m makes a pseudo key event あ, but the control key remains pressed, so this event will be recognized as control+あ unwantedly. I modified the initial patch so that the modifiers in utf8 character events are ignored.
Although it works fine now, utf8 string still cannot be displayed in the text editor :p
%%%Hi, quick review of the patch, though I'm not exert in this area there are a few Q's I have about this patch.
see ./source/blender/blenfont/intern/blf_lang.c's use of setlocale()
%%%Hi Campbell, sorry for late reply.
setlocale() is essential here. If removing this, no utf8 character will be inserted. In my patch, setlocale() uses system locale, but the other locales should be OK if it's available on the system. So, probably BLF_lang_set() can be used instead of setlocale(), but I couldn't use it here because I don't know if GHOST is permitted to include BLF.
I think (256 * 6) is sufficiently large value to input one sentence in any languages. If using small array and the string exceeds this length, Xutf8LookupString() sets the status "BufferOverflow". In such case, we still can receive the string by calling Xutf8LookupString() again after expanding the array, but the code becomes somewhat complicated.
%%%Updated. (XIM_non-latin_V3.patch)
Changed the buffer size to 16 * 6 = 96 bytes. If the length of the input string is larger than 96 bytes, allocate another memory area and call Xutf8LookupString() again.
The other apps use very different sizes. For example, Wine and Emacs use 24 bytes and 513 bytes, respectively.
Wine: http://source.winehq.org/source/dlls/winex11.drv/keyboard.c#L1321
Emacs: https://github.com/emacsmirror/emacs/blob/master/src/xterm.c#L6372
If WITH_X11_XINPUT=OFF, use 1 byte array to store one null character.
%%%Oops, updated again... sorry. XIM_non-latin_V4.patch.
The buffer size must be 6 bytes or larger even if WITH_X11_XINPUT=OFF.
%%%XIM_non-latin_V5.patch
Changed to set utf8_buf NULL if WITH_X11_XINPUT=OFF. NULL pointer means not an utf8 character.
BTW, the documentation of GHOST_EventKey's constructor needs updating because the parameter btf8_buf is not described.
%%%XIM_non-latin_V6.patch
Removed setlocale() in GHOST_SystemX11.cpp. Instead, moved BLF_lang_init() call in WM_init() so that it will be called before wm_ghost_init(), and modified BLF_lang_init() to call setlocale() even if U.transopts&USER_DOTRANSLATE is zero.
%%%XIM_non-latin_V7.patch
Enlarged utf8_buf- [ ] by adding extra 5 bytes. The last 5 bytes of the buffer won't be used to obtain the utf8 data but should be useful to avoid the segfault, though such segfault have never happened on my system. Not using the extra memory area at the end of the buffer is potentially dangerous, because the constructor of GHOST_EventKey reads 6 bytes unconditionally even if the actual data is only 2-3 bytes.
%%%XIM_non-latin_V8.patch
Reverted the changes of the patch V6 because UI translation became not working.
blf_lang_set() cannot be used instead of setlocale() because GHOST_CreateSystemPaths() has not been executed yet. Don't worry, setlocale() in GHOST_SystemX11.cpp should not conflict with the other locale settings in Blender, because this setlocale() is executed earlier than all of them so its locale simply will be overridden by them, and XIM can work after locale is changed.
%%%XIM_non-latin_V9.patch
Refreshed. (only compensate for offset, no functional change)
%%%This patch fixes the problem of inputing ' " and accented letters in the Text Editor and in the UI elements
It still doesn't work for the 'Console' though.
+1
(ps I had to apply the patch with
patch -p1 < XIM....patch
. next time it's better to create the patch from inside the blender folder)%%%%%%@dfelinto
Thanks for the testing.
This patch solves only X11 specific problems. I think the console issue should be fixed by another patch.
Sorry, this is a Debian package style patch because I'm testing it in PPA in Launchpad. (https://launchpad.net/~irie/+archive/blender)
%%%XIM_non-latin_V10.patch
Updated for the style cleanup in r45127 and r45130.
No functional change.
%%%Two things:
%%%XIM_non-latin_V11.patch
Don't use setlocale(), and don't open connection to XIM server on startup. The connection will be opened when the first KeyPress event is received after entering the event loop.
Use GHOST_PRINT() instead of printf() to indicate that the XIM connection is opened or XIC is created.
@nazgul
Thanks for the review.
"XIM input context destroyed" is an error message that will be displayed only when the XIM server unexpectedly shuts down.
GHOST_PRINT won't be enabled by -d flag but GHOST_DEBUG macro should enable it. (Currently GHOST_DEBUG seems to be broken.)
%%%XIM_non-latin_V12.patch
Not only KeyPress event, but also FocusIn event opens the XIM connection and creates the input context. Typically FocusIn event occurs earlier than KeyPress event, so checking the KeyPress event works as a fallback.
%%%XIM_non-latin_V13.patch
Refreshed. (no functional change)
%%%XIM_non-latin_V14.patch
Updated for style cleanup r46787.
Can anyone review this patch again or merge into trunk?
%%%I have tested this patch and confirm that it works as expected with IBus and Ubuntu 12.04. It does not interfere with non-XIM input method for non-latin languages such as russian, and does not change visible behavior when WITH_X11_XINPUT is disabled. The only thing XIM user have to remember is to switch off IBus with ctrl+space after finishing non-latin text input. I hope it's not a big deal for XIM users.%%%
%%%Nice work! I think it would be really great to tell Ton to let it in the coming release. :)
http://www.blendernation.com/2012/05/22/developer-meeting-notes-may-20-2012%%%
%%%XIM_non-latin_V15.patch
%%%attached edits to XIM_non-latin_V15.patch, called XIM_non-latin_V15_cleanup.patch
only functional change was to replace printf with GHOST_PRINT%%%
%%%applied r48827.%%%
%%%Thanks for the edit and the applying!%%%
