FIX: python KX_SoundActuator::startSound no longer requires an existing handle to play
FIX: python KX_SoundActuator::startSound no longer requires an existing handle to play:
If you look at the C++ code, you will notice that in startSound you NEED to have played the sound using logicbricks before playing the sound with Python. There doesn't seem to be a technical reason for this. With that in mind I lifted this requirement by moving play() out of the handle != NULL condition.
Thanks for reporting this bug, I fixed it just a little bit differently, to not duplicate the play call.
Closing
Joerg Mueller (nexyon) closed this task as Archived.Feb 24 2012, 8:35 PM
