Which part to snap in volume snapping is removed
Following with report #30197, now the useless align button is no longer present in volume mode. However, a button has been also dropped out: in volume snapping also, the "Which part to snap onto the target" select button is not present. However you still should be able tho select which part. Actually you still can: if you select another snapping mode than volume, select a new part to snap and go back to volume mode, you can see it works. So the functionality is still OK. Then you should be able to select which part to snap, without having to get out and in from volume snapping mode.
Regards,
Pep.
(I tried revision 44463 in Windows)
Fixed in revision 44798.
Martin Poirier (theeth) closed this task as Resolved.Mar 10 2012, 10:40 PM
