Loop Select should not become a Redo History Item. #30375
2 Participants
Reference: blender/blender#30375
%%%If you select an Edge Loop with Alt+RMB it gets inserted as an item in the Redo History.
What this means is that you cannot sequentially delete a series of Edge Loops with Shift+r -- you have to hit F3 then 2 to activate the "Delete Loop" command from before.
I do not see the value of having the Loop Select in the Redo History. You cannot repeat it later on (either with Shift+r or with the F3 menu). Not having it in the way would enable other commands to use Shift+r.
Thank you.%%%
%%%Select edge loop and ring will now avoid registering in undo list (svn rev44482).
Thanks for the report, closing.%%%
