Import OBJ and using existing material *NEEDS CORRECTION* #30380
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
8 Participants
Reference: blender/blender-addons#30380
%%%For a detailed discription see here: http://blenderartists.org/forum/showthread.php?234521-Import-OBJ-but-using-existing-material
The Patch does work already and has been reviewed by Campbell.
In my opinion this should be done for all kind of Meshimporter.%%%
%%%The problem with this patch is it modifies existing materials, IMHO it should use them as-is without any modifications.%%%
%%%I don't understand. In my view as a user an not as coder it does exactly this: It uses existing materials, it doesn't change them. Thas what this patch is for.
Maybe it changes existing materials within Blender but this it's not visible for the user ?%%%
%%%Hi. double checked this patch and it still changes existing materials.
Try the following.
IMHO it should use the existing material but not touch it in that case since this material can be used in many of your own objects.%%%
%%%I just added this after line 203:
if use_material_exists:
Now it doesn't change existing materials anymore.
%%%I just merged the Patch with the newest build (blender-2.62-r45133, Sun Mar 25 03:09:10 2012).
The problem with changing existing materials is fixed now.
But I'm to stupid to upload files here, I always get an error when I click on "save changes" in the "attachements" register.
So I added it here: http://blenderartists.org/forum/showthread.php?234521-Import-OBJ-but-using-existing-material
%%%@Campbell Barton
Is my latest fix working for you the way you expect it ?%%%
%%%It is a dream come true that I found your thread in blenderartists.org .
But the thing is not working for me.
The 05-Feb-12 version gave no errors, but didn't work either.
The 25-Mar-12 gave 3 or 4 errors.
Then I downloaded the 2.63 RC1 blender and it works! This is extraordinary!
Thank you so much. I also support this feature being added to (at least) OBJ, 3DS and DXF imports.
This is a VERY needed feature for people who use blender as a visualization tool.%%%
%%%@Campbell Barton
I've updated the Script for Blender 2.67, see here: http://www.blenderartists.org/forum/showthread.php?292369-Here-is-a-little-timesaver-if-you-use-Sketchup-to-model-buildings
Is it OK from a Coders view ?
Would be cool if you would commit for Trunk.
%%%I just tested the script with some .obj files in Blender 2.67a and it works beautifully here. When importing third party object collections or when (re)importing parts of models created in other software, this one option enables a smoother workflow than has so far been possible.
Earlier, without the option there were basically two options when adding new geometry from obj files to an existing file:
Option 1 may leave unwanted materials in the scene and takes time, option 2 works but involves steps that are now unnecessary and leaves an extra blend file behind. As a user, I would very much like to see this feature to be integrated in the official import script.%%%
Added subscriber: @bliblubli
@alain-2 did you update it for 2.74? It's a little but nice addition.
Added subscriber: @BrendonMurphy
Archiving, op 3 years old, no resolution here.
@alain-2 feel free to create a fresh task if this patch is updated & still valid
Added subscriber: @dimumurray
Any chance we'll see this feature fully integrated into the Import-Export OBJ format add-on?
Added subscriber: @Dimitar
Any updates on this? I find it quite important to be able to assign existing materials with materials matching the same name from an imported obj
I have a little hack that I have been using to remove duplicate materials:
I've implement a few lines to "use existing" Material again.
People still ask me to modifiy the Script to implement that time saving function:
init.py
import_obj.py
Can some Prodevelopper please test it ?
Would be great to implement that to trunk forever :-D
