Boolean operator intersect after edge split do not work #30447
Reference: blender/blender#30447
%%%Hello,
when i try to use boolean modifier intersect after edge split modifier,
either with applying the edge split modifier or not, a message appears
"Cannot execute boolean operation" in the boolean modifier.
When i dont redirect the blender error messages to a file, blender hangs then
and needs to be restarted.
I made several attempts, for error messages see error.txt
To reproduce, open provided blend and try to apply boolean operations with
the cube and the object shaped like a big T.
Without edge split, incorrect results occur.
With edge split it doesnt work at all.
The T mesh object was converted from a Text object, with double verts removed and
separating loose parts of the mesh and origin to geometry.
Tested under Ubuntu 11.10 64 bits, blender rev 44610.
Specs:
CPU: i7 2600
GPU: Geforce GTX 580
RAM: 16 GB
%%%Boolean operation cam work only with volumes, but adding edge split makes mesh non-manifold which makes boolean modifier behaves incorrect.
The only real issue i can see here is incorrect handing of T letter which happens because of degenerated faces (there's some zero-sized faces where | is connecting to --). This happens because Carve can't detect if this face is inner or outside. Probably code-side workaround would be not sending degenerated faces to Carve, but will also inform Tobias aboud such problem, maybe we can have some support from Carve side.%%%
%%%unfortunately that code-side workaround wouldn't work because it'll make mesh non-manifold. But can think about much easier workaround for this case: apply remesh modifier on text so there'll be no more degenerative geometry and boolean operation should just work.%%%
%%%Marking as ToDo, after discussion with Sergey. http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Tools#Boolean_Modifier %%%
