Render time estimation
Closed, InvalidPublicPATCH
Project: Blender Extensions
Tracker: Py Scripts Upload
Blender: 2.62
Category: Render
Python: 3.2
Script name: Render Time Estimation
Author(s): Jason van Gumster (Fweeb)
Status: >Contrib
Using the average render times of earlier rendered frames, calculate an estimated time to completion and display this is UV/Image editor render view.
This is specifically for animations. Also while it works fine in 2.62, it works nicer with this patch (http://projects.blender.org/tracker/index.php?func=detail&aid=30417&group_id=9&atid=127) applied.
Small update to only render time information when the Render Result is visible in the UV/Image Editor. Also added wiki link.
Added to contrib (and uploaded a version here for the wiki). Further dev will be in contrib.
This version (0.3.0) no longer requires the patch mentioned in the original description. Instead it uses bpy.ops.render.opengl.poll() as a test for whether or not Blender is currently rendering.
Jason van Gumster (thefallenweeble) changed the task status from Unknown Status to Unknown Status.Mar 6 2012, 12:02 AM
So this is giving me an error o Blender 2.75a. any new Updates?
Computer Info:
Macbook Pro (Early 2011)
2.3 GHz Intel Core i7
AMD Radeon HD 6750M 1024 MB
16GB Ram
Still works here. What is the specific error that you're getting?
Thanks you, I did just update it myself in addons contrib, not much needed changing. There's little difference between the 2 files. Thanks for looking at it, I'll look at adding some prefixes to the class soon. Thanks again.
