Modifiers with use_apply_on_spline = True do not work on curve with shapekeys #30561
2 Participants
Reference: blender/blender#30561
%%%The attached scene has been made by:
- Loading factory defaults
- Removing every object
- Adding a plane mesh, scaled to 5
- Adding a curve path, translated x=0 y=0 z=4, with extrusion=1
- Putting a shrinkwrap modifier on the curve with target the plane
- Adding a shapekey to the curve
Expected behaviour:
Actual results:
If I disable use_apply_on_spline, the modifier works (of course one doesn't see much because the generated surface is orthogonal to the plane thus projects onto a line).
If I toggle edit mode on the curve, the modifier temporarily works (I see the expected result while in edit mode)
If I remove the shape key, it also works.
Note that the extrusion is not needed to trigger the bug. It just makes it more visible, and problematic (without extrusion I don't care about use_apply_on_spline being True or not)%%%
%%%Fixed in svn rev44921. Thanks for the report, closing.%%%
