"select/deselect all"-menu for lattice doesn't default to TOGGLE
when using the "selection invert" for a lattice (added in 44930) and then using the menu for "select/deselect all", you get an invert again.
the menu needs to default to the toggle action:
it should be like this in "trunk/blender/release/scripts/startup/bl_ui/space_view3d.py":
class VIEW3D_MT_select_edit_lattice(Menu):
bl_label = "Select"
def draw(self, context):
layout = self.layout
layout.operator("view3d.select_border")
layout.separator()
layout.operator("lattice.select_all", text="Select/Deselect All").action = 'TOGGLE'
layout.operator("lattice.select_all", text="Inverse").action = 'INVERT'
(currently the ".action = 'TOGGLE'"-part is missing)
Fixed in r44974.
Thanks for reporting! :)
Bastien Montagne (mont29) closed this task as "Resolved".Mar 18 2012, 8:56 PM
