Imports cameras, images and point cloud of a Bundler scene #30893
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
6 Participants
Reference: blender/blender-addons#30893
Project: Blender Extensions
Tracker: Py Scripts Upload
Blender: 2.62
Category: Import Export
Python: 3.1
Homepage: http://koelzk.crispy-cow.de
Script name: import_bundler.py
Author(s): Konrad Kölzer
Status: Open
Features
This script imports a Bundler scene into Blender. Bundler is a free structure-from-motion software developed at the University of Washington that automatically generates an image-based representation using unordered images as input (see more here: http://phototour.cs.washington.edu/bundler/).
A Bundler scene consists of a set of images with reconstructed camera parameters (position, orientation and focal length) and a point cloud that represents a rough estimate of the scene geometry. The import_bundler.py script loads the cameras and point cloud into Bundler. Associated images are added as textured quads in fron of the camera. Imported Bundler scenes can be used as a sketch for 3d modeling.
Setup
The script can be installed as Blender addon in "File > User Preferences > Addons > Install addon...". After that it is displayed as single entry. Click on the checkbox on the right to enable the addon. Now you can start the Import by selecting "File > Import > Bundler (bundle.out)".
Manual
Setting up Bundler is not easy, so feel free to use one of the following scenes for testing:
http://koelzk.crispy-cow.de/temp/hanau_images_800.zip
http://koelzk.crispy-cow.de/temp/test3.zip
After you installed the addon, just click on "File > Import > Bundler (bundle.out)". Now you can select the bundle.out file of your Bundler scene. After the import, you should see something like this:
http://koelzk.crispy-cow.de/temp/blender_bundler_import1.png
http://koelzk.crispy-cow.de/temp/blender_bundler_import2.png
If something went wrong, please let me know.
Some details about the imported data:
Current limitations of the import:
Added subscriber: @brothermechanic
Hi!
Great project!
But i’m can’t import bundler.rd.out (from vsfm) to blender
I have error
[code]
Traceback (most recent call last): File “/home/bm/.config/blender/2.69/scripts/addons/import_bundler.py”, line 282, in execute load(self, context, path) File “/home/bm/.config/blender/2.69/scripts/addons/import_bundler.py”, line 254, in load bfr = load_scene(scene_path) File “/home/bm/.config/blender/2.69/scripts/addons/import_bundler.py”, line 151, in load_scene bfr = BundleFileReader(os.path.join(filepath, “bundle”, “bundle.out”)) File “/home/bm/.config/blender/2.69/scripts/addons/import_bundler.py”, line 90, in init f = open(filepath, “r”)
FileNotFoundError: [Errno 2] No such file or directory: ‘/home/bm/test2/v3/ver3.nvm.cmvs/bundle/bundle.out’
[/code]
My blender version is 2.69.
Fix it please.
with blender-2.61 don't work too
my scene http://yadi.sk/d/s9trT_M4CzFW4
Added subscriber: @rayfigs
Hey brothermechanic,
I ran into this problem as well. The importer expects a certain file name and file structure. That being said if you try to use the scene the author provided to check out exactly what the addon expects. http://koelzk.crispy-cow.de/temp/hanau_images_800.zip
You'll need to find where bundler saved a few files: your image directory, your .out file and your list.txt file
Once you've found these files follow the below instructions:
Rename your file to bundle.out
Put your bundle.out file in a directory called bundle
Take the bundle folder and copy it to your image directory
Copy your list.txt file to your directory
Now try to see if the importer will work :)
Now I'm running into the problem of not being able to see the images in the viewport, despite setting shading to glsl and setting the viewport mode to texture display XD
Cheers,
Ray
Hi,
If you have problems making the images appear in the viewport, check this link:
http://koelzk.crispy-cow.de/article/9/importing-bundler-scenes-to-blender#c000025
Added lights in the scene and seems to have fixed the issues.
Hi, rayfigs!
Thank you so much !!! I do it!
I don't know where is new fixed version (i get that https://developer.blender.org/file/info/PHID-FILE-jcod7twrkeoopplmawlo/)
But i follow your instructions of file placement and get it!!!
Thank you!
http://i.imgur.com/FlxLToT.jpg
http://i.imgur.com/bYiUdXf.jpg
http://i.imgur.com/g1EP5Wv.jpg
Added subscriber: @SebastianRothlisberger
Hello
Is it possible to add forsed select focal leight and sensor size of cameras, and import without image planes?
You can modify/extend the import_bundler.py to your needs.
Import without image planes
Just comment out the call to
addImagePlane()
in line 242 and 243.Forcing a specific focal length
If you know sensor size and focal length in mm, you should replace line 236 and 237 with the following code:
sensor_width
andsensor_height
are the sensor width and height in mm.focal_length
is the focal length in mm. As you can see in the existing code of script, I am using the same equations, however I use the image resolution and focal length in pixel.Hello
Thank's for reply
This is not so simply for me
https://bpaste.net/show/c2d10ee3c33f
I do this changes in scrept, but get this error
[code]
NameError: name 'planeObj' is not defined
[/code]
Then i uncoment planes and all import as usually
and cameras do not have trye fical leight and sensor
http://wstaw.org/m/2015/05/13/plasma-desktoptZ4168.png
This is what i want
http://wstaw.org/m/2015/05/13/plasma-desktopay4168.png
And it will be usefull if camera settings will be as import option
Thank you anyway
Sorry, I forgot something. You are getting the error, because if you are commenting out line 242 and 243, you also need to comment out line 254. Last but not least I added some code to pass the focal length and sensor size in mm to Blender.
The resulting
addToBlenderScene()
funciton should look like this then:Thank you for help.
Last question.
The image name is "0000X.jpg" (for ex), its camera name is "Camera X"
Can you modify your script that cameras have names like its images, like "Camera-0000X"?
It will be more properly i think, and more useful to work.
Thank you for script!
Added subscriber: @BrendonMurphy
no activity 18 months, Archived.
Added subscriber: @SteffenD
