Fluid obstacle checkbox has no effect
Closed, InvalidPublic
Fluid obstacle is included in simulation regardless of "Object contributes to fluid simulation" checkbox state.
r44136 win64
This is correct, the problem is if it is possible to support.
Please test if commit rev 45655 fixes it for you. If not, I will fix the UI to remove the checkbox.
Thanks!
Tested with 45659 (Please let me know if I need to test with exact version)
For now result is the same.
Reverted rev 45655 and commited an UI fix in rev45832. Sorry it does not seem that the elbeem code supoprts obstacles with animated enabled/disabled property.
Thank you for reporting this issue!
