Cant Select Verts/Faces in Cutaway view.
Closed, InvalidPublic
Group: current SVN version
Resolution: Fixed
Category: Interface
There is a Bug with new Edit mode and the new Alt+B Cutaway view.
* Enter edit mode with the cube for eg
* Enable cutaway view. (Alt+B)
* This affects Verts and faces (Edges select fine) so use one of them.
* Turn display to wire view OR Shaded view with "Limit selection to visible (Clipped with depth buffer)"
* Try right click on a vert or face, lassoo or border select- None of them work.
Ton Roosendaal (ton) changed the task status from Unknown Status to Unknown Status.Sep 29 2005, 11:30 PM
This task was automatically closed as archived as part of migration, because the project or tracker this task belonged to is no longer active.
