Cut/Copy/Paste objects and elements #31214
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#31214
Project: Blender Extensions
Tracker: Py Scripts Upload
Blender: 2.63
Category: 3D View
Python: 3.2
Script name: Cut/Copy/Paste objects and elements
Wiki page: http://wiki.blender.org/index.php/Extensions:2.6/Py/Scripts/3D_interaction/CutCopyPaste3D
Author(s): dairin0d
Status: Open
%%%Features
This addon makes it possible to cut/copy/paste objects and elements across different layers, scenes and Blender files.
When enabled, it would add a Copy/Paste panel to the Tool Shelf, and register Ctrl+X, Ctrl+C, Ctrl+V shortcuts for 3D view.
Options:
NOTE: currently cut/copy/paste operations are implemented only for objects.
Installing
Hit
Ctrl+Alt+u
to load up the User Preferences (orFile
menu ->Save User Settings
).Click the
Install Addon...
button at the bottom, then navigate to yourspace_view3d_cut_copy_paste.py
script.Checking the little box on the right of the Addon entry in the list to enable it.
If, for some reason, you have a hard time finding it, you can search for
Cut/Copy/Paste
, or click on the3D View
button on the left.If you want to keep this addon available at all times, follow the above steps on a fresh
.blend
(one youCtrl+n
d), then hitCtrl+u
at this point. The next time you run Blender, you won't have to repeat the above.%%%
Added subscriber: @BrendonMurphy
Assigning to self.
It's worth investigating this furthur. cut/copy/paste works as advertised, I wonder if there's similar function in Blender or if it's worth adding this functionality to the copy attributes addon.
Sorry for such a late reply,
Blender seems to have some very simple built-in copy/paste functionality:
This addon attempts to provide a more advanced "3D clipboard" functionality, emulating the feel of cut/copy/paste operations from many other graphical editors. It would be awesome if it was built-in in Blender, though :-)
The Copy Attributes addon seems to serve a completely different purpose (transferring properties from the active object or element to the selection).
Added subscriber: @bliblubli
Yep, it owuld be nice to continue the work done by Ton to make it a really complete feature.
For the addon, already really good job. To fine-tune, Ctrl+V could also allow to link data.
hi, still working well, this should be done in blender code, hopefully it will happen around 2.8.
on a side note, I'm trying to see reasons for the Cut & having trouble justifying it.
@dairin0d thanks for another good addon.
Closing as archived.
If this addon will become obsolete, I would be extra happy :-)
I implemented Cut primarily for the sake of completeness (users accustomed to other programs would expect to be able to do this), but there are some cases when it might come in handy:
Perhaps it might be a good idea to ask on forum/mailing list for other possible uses of the Cut.
Added subscriber: @Jackson_Counts
