In old compositor, connection from color output to scalar number input simply converts RGB to brightness, however afer tile branch merge it seems to convert to brightness*alpha so the results of post processing will be much different from older ones.
I don't know if this change is intended, but it should irritate us because we have to modify the node settings in most of all older .blend files.
r46794
Ubuntu 12.04 amd64
Comment Actions
I just posted the patch for this problem:
http://projects.blender.org/tracker/index.php?func=detail&aid=31534&group_id=9&atid=127
Please check it.
Comment Actions
Has the compositor's behavior been accidentally changed? Or, should I modify my existing .blend files???
