m3addon: Exporter and importer for the m3 file format (m3 is the model format of Starcraft 2) #31916
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#31916
Blender: 2.69
Category: Import Export
Python: 3.2
Homepage: https://github.com/flo/m3addon/
%%%The addon allows to import and export m3 model files. M3 is the file format used by Starcraft 2.
The m3 file format does not only contain mesh and materail data, but also meta data like, Lights, Particle Systems, Projections, Forces, Rigid Bodies and many more. Since for example materials do not match Blender materials perfectly, the addon used a lot of custom collections to represent them, which can be edited via new panels in the Scene Properties Tab.
In order to simplify the editing of the meta data which has something like an "impact area", the addon uses bones with custom shapes in order to outline for example the spawn area of m3 particle systems.
Files of the m3addon:
Utility scripts contained in the m3addon:
%%%Uploaded the current version to this tracker.
The major improvements compared to the previous version are:
I would like to upload a version which is compatible with 2.69 and has a ton of new features and bug fixes but I can't find a upload button.
Also the description is outdated. The newest version of the m3addon no longer generate the m3.py file. Instead the new m3.py file parses the structure.xml file in order to figure out how to import and export m3 files.
Added subscribers: @Sergey, @brecht, @dmcgrath
As mentioned on IRC, you can just change the "Action" drop down box here to "Upload File" to attach another file to the report.
As for editing the tasks, I don't know why you are not allowed to edit your own descriptions, but @brecht or @Sergey may know?
Uploaded the current version of the m3addon which is compatible with Blender 2.69.
We should automatically allow authors to edit their descriptions but we need to do some coding for that, for now I've given you some extra permissions so you can edit the description.
Also, upload can be done using drag & drop into the text field (there's a little upload button in the header that tells you this but it's not so obvious).
Thanks for the permissions brecht, I updated the description.
Removed subscriber: @dmcgrath
Added subscriber: @BrendonMurphy
Archiving, op over 3 years old, no activity 2 years.
@florian-5, I noticed your git page does well, better to keep distributing & maintaining in your page.
Thanks for submission.
