Mesh saved in 2.63 with legacy format have holes instead ngons
Closed, InvalidPublic
Saving with legacy completely removes ngons (not replacing them with tris or quads).
System independent (windows, linux, x32 & x64).
i can confirm this for 2.63a, .blend has holes, no matter if loaded with pre-bmesh blender (2.59 tested) or 2.63a
seems to remove not only ngon faces, but also quads at T-conjunctions (but can't tell for sure)
mentioned quads are also ngons (5 points),
so this is ngon problem only
In fact, this is working as expected: this option only converts 3 or 4 corners ngons, *it does not execute implicit triangulation*, as such process may produce some unexpected results. So if you want to export a mesh having "real" ngons, you first have to manually triangulate it (ctrl-T in Edit mode, or do it/fix it by hand).
Will add a warning in the tooltip of this option.
Thanks for the report anyway, closing now.
having holes in mesh is hardly what i expected. quite useless function...
