Instance particles not rendering when Linked
I have only noticed this in cycles as of 2.63.
Library Linked instance particles show up in the viewport render but not F12 render:
Open a new scene.
Duplicate the cube.
Use one of the cubes as a group for particle instances on the other cube.
This scene renders fine.
create a group of the original cube and the particle group.
Link this into a new blend file.
The viewport render works fine.
The F12 render does not show the particles.
Brecht, could you please check on this? Thanks!
Could redo some issues in 2.63, but not anymore in 2.64, so will assume this is fixed. Otherwise please attach .blend files, the instructions are not 100% clear about the setup.
Brecht Van Lommel (brecht) closed this task as "Resolved".Sep 27 2012, 5:55 PM
