Copy/Paste UV data between groups of vertices in the same mesh object #32562
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
6 Participants
Reference: blender/blender-addons#32562
Project: Blender Extensions
Tracker: Py Scripts Upload
Blender: 2.63
Category: UV
Python: 3.2
Script name: Copy/Paste UVs
Wiki page: http://wiki.blender.org/index.php/Extensions:2.6/Py/Scripts/UV/Copy_Paste_UVs
Author(s): Jace Priester
Status: Open
%%%Given a set of vertices in a mesh object which has been duplicated, this script allows for copying the UV coordinates from one set to the other.
Select the source vertices and U->Copy UVs, then select the destination vertices and U->Paste UVs.%%%
%%%what a useful tool! thank you for creating this addon. This should be in trunk imo!%%%
Added subscriber: @RomboutVersluijs
Ive got this question about this plugin. I cant copy the UV from one object to another in the same mesh. Tried cipying the vertices and than pasting it but blender keeps crashing
Added subscriber: @PaulGeraskin
This is really powerful addon! What is the status of adding it to the blender addons?
I think i can add this addon into the blender. if @JaceP does not mind. I'll talk to @Ideasman_42 about it in IRC.
Here is my test of the addon. It's really powerful: http://youtu.be/Iy1RI6KNZ_M
Ok, Ideasman42 is ok to add this script. I did the script compatible to pep8.uv_copy_paste_uvs.py
Added subscriber: @DiThi
Hi, I just wanted to nitpick it's not really PEP8, there are lines longer than 80 characters. You can store e.g. "source_object.data.loops" in a variable to reduce line length, and that also makes the script a little bit faster and more readable. Strings can be split like this:
URLs don't need to be split. When there are too many levels of nesting in Python you can't have less than 80 chars, it's a symptom code needs some refactoring.
When editing PEP8 compliant code, I have my editor split in at least 3 columns or tiled with other window. Sorry if I'm being too nit-picky, I'm also writing a style guide for an internal project.
Cheers
Hi @DiThi . Could you write a mail here http:*lists.blender.org/mailman/listinfo/bf-python ? As I made a post to accept the script here http:*lists.blender.org/pipermail/bf-python/2014-June/006255.html .
I used Autopep8 tool to make it compatible.
Ah, I see autopep8 doesn't wrap lines by default.
@PaulGeraskin That's where I saw your script.
Added subscriber: @zanqdo
Hi, how does this differ from the Transfer UV Maps operator?
I think I can answer that my self. This works inside the same mesh.
Ok, i changet lines. Attached modified version.uv_copy_paste_uvs.py
Guys! After the review of IdeasMan42 the addon is added to the blender-contribs!
https://developer.blender.org/rBACcfa509162f9ec0cc7873a61a5fa5be9e470e617a
Jace Priester thank you.
The addon is in repo. Close the task.
