Collada: Import from Lightwave creates Error when rendering with LuxRender
.dae file exported from Lightwave 11.0.3.
Import into Blender.
Save.blend file.
try to Render with LuxRender and error message "Index String not found' error on hitting render.
Using:
OSX 10.6.8
LuxRender 1.0
Blender 2.63
Attached the original files if it helps.
Collada Import bugs will be investigated for Blender 2.65
For this reason this Report has been set as "Closed/Todo" and linked from our wiki page.
http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Import_Export#OpenCollada
You can still update this report with more detailed information until it gets reopened/fixed.
Gaia Clary (gaiaclary) closed this task as Archived.Sep 25 2012, 9:38 AM
Tested and did not get the error from the dae file. Also no error from the blend file. Maybe the updated Blender/LuxRender fixed the problem.
Blender 2.68a win32 build
Win7 64bit
LuxRender 1.2.1 win32 opencl
