NURBS separate operator failing
Hit P on the provided file. I don't think that's doing the right thing?
This isnt a bug, since the operator is working `as intended`, however this is fairly not-useful behavior.
- The limiration is you can only separate whole curves atm.
Added as a TODO item.
http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Tools#Curves
So this is really to move a curve object's spline to a new curve object.
Sounds useful to me, but i wonder why there is no Split operator. It would move selected points to a new spline in SAME curve object (effect: selection disconnected from rest of original spline). This should also work with a single point selected:
* = points, [*] selected point
*------*---------*--------* Spline1
*-----[*]--------*--------* Spline1, Split()
*------* + *---------*--------* Spline1 and Spline2 (split point is actually at same co of course)
@Sebastian Nell
Agree improving separate and adding a split operator would be handy.
However the split tool should probably split as the mesh Ykey tool does, where it separates selected from unselected.
