Deprecated vars with no UI access are used in blender.
Closed, InvalidPublic
draw_ghost_poses uses vars the UI cant access.
Apply patch to get errors.
For the record (as discussed with Campbell earlier):
I was halfway through porting ghosting stuff over to a unified system via AnimViz settings (as for motion paths) before life caught up at that point, and I needed to abandon that project.
AFAIK though, the UI should still be going through the relevant RNA properties for setting these though.
I see no reason for using the bug tracker for an internal development todo. As guidelines say: this tracker is for end user issues!
Yep, closing since this works correctly from the UI.
