particle systems of type emitter got wrong rotation if random rotation above .1 #33705
2 Participants
Reference: blender/blender#33705
%%%Problem : With some random rotation values, rendering is buggy (cycles and BI, windows and linux)
Changing the emission number sometime resolve the problem.
Blender 53377
Steps : Default scene, add a plane, on that plane a particle system with the cube as rendering object. Make the cube smaller on a side to see the orientation bug.
Render, all is ok.
Now activate rotation and change the random value under "velocity/hair" so that it is above 0.1 , render again, most of the cubes are invisible and with wrong rotation.
Example file : I did a file for better understanding, just render, it will be wrong, increment number of emission and rerender, all will be fine.%%%
%%%I find our particle system quite confusing :)
The demo file does do unpredictable things, but there's a couple of things:
But further - I can't figure out in this example what the rotation bug is...%%%
%%%Thanks for the answer,
I couldn't reproduce the rotation bug with simple cubes. I can't post the original file because of rights and file size is huge anyway. But i post some renders of it.
Only difference between the 2 renders is that i incremented the emmision number of +1, which made the bug disappear.
in bug.jpg, all particles are in the same wrong direction, no more randomisation. I didn't find any logic in that bug appearing or not, it's very random. However, most of the time it comes from changing the random rotation value.%%%
%%%The simpler the file you provide the better. In your example too many things go on, so I cannot see what the issue is really.
Random locations of particles, combined with random rotations, combined with frame stepping, etc... note that particle rotations can only work on 2nd frames or more.
%%%After an hour of try to get the bug on a simple scene, i had no success. But the bug still hapen on the grass scene (with very complex setup, i tried to modify many things, but sometime modifying a parameter "activate" the bug and sometime, modifying the same parameter does not activate it... so it's hard to find the source.
From my many test 2 things came out to be sure :
I will try to find the source of the problem in a simple file, but it is not simple.%%%
%%%ok, another hour of try and succeed, whoa it will start to be a full time job to hunt bug ^^
New file attached very simple :
Factory settings, default scene, add a plane, part system on it, cube as render object.
Activate random rotation under "velocity/hair".
Note : Only works in random or jittered emission, grid is ok (after switching to grid, if you revert back to random or jittered, change the random rotation slightly to reactivate the bug)%%%
%%%Collecting all particle rotation errors here (4 already):
http://projects.blender.org/tracker/index.php?func=detail&aid=32340&group_id=9&atid=498
Sorry, but for time being this feature is not in maintenance.%%%
