Shadows produce artefacts in vertex colour baking
Ubuntu 12.04
NVIDIA Corporation G94 [GeForce 9600 GT] (rev a1)
2.65.3 r53494 (first revision with vertex colour baking)
Some vertices are erroneously marked as shadowed when baking to vertex colours. The affected vertices changes between two sets each time the bake is run.
The attached .blend file contains an object with baked shadows. Grease pencil circles show the locations of the artefacts. Initially, two artefacts are visible: one on the back of the head, and the other on the left ear. If it is baked again (press Bake in the render buttons), two other artefacts appear instead of the original two. If it is baked again, the original two artefacts appear again.
Taking this for myself, since vcol baking was my patch.
But Brecht, if you have any ideas please let me know :-)
Whoa, thanks for fixing this! That's the kind of thing I had intended to do, but I failed on my first attempt. I think I was shifting the coordinates along the face instead of away from it - which I thought might work because the rasterised UV bakes don't seem to suffer from it.
Anyway, thanks :)
