rendering a particle system with emitter increase file size #33745
Reference: blender/blender#33745
Linux and Windows, intel GMA
error in r53476, couldn't find a working version
File size increase after each render that follow a particle system modification.
Open attached blend (default scene with a plan with particles on it), it's some Kb big.
hit F12 (you can cancel after it starts rendering),
save again, the file is many Mb big.
Every time the emission number is changed, then a render happen, the file size increase.
Note : Even setting the emission number to 1 (so the scene is a just containing a plane with 2 cubes) doesn't resolve the problem.
%%%After furher testing, setting the emission number value back to 1 help if a render is done before saving.
On simple scene it's ok. But on big scenes where the steps before rendering start take time (1 min on my computer on my current project) it makes saving really slow or huge.
I made a script in the mean time that set all emission numbers for all particle system back to 1, render then reset the values to what they were and save. Thus, files are small, save can be fast and loading is fast. But as I said, on heavy scene the rendering can be very slow, thus making save take more than a minute.%%%
%%%Issue is caused by the fact that all particles data is saved to .blend file. Before you render, particles are not generated at all, so there'll be small file size. Once you started rendering (or enabled viewport display of particles) they'll be generated and saved to .blend file.
Not sure if it's possible to avoid saving ParticleData to .blend file with current design.%%%
%%%Particle caches were always saved in the past (pre 2.5 too), but they have been growing in size enormously.
Also if you add fur to characters, things grow very fast.
It's a bit "sign of the times" too, more memory, bigger disks, faster computers... we can only try to be careful here.
On the positive side: we want to look into Alembic support once, which has excellent support for compressing animation point data.%%%
%%%Ton, what's really annoying here is that it's not just a point cache in this case. If you'll use external case file size will grow up after adding particles as well. As i understand, it's current state of all particles (ParticlesData structure, contains current size, position, some other stuff -- total 200 bytes) per single particle will be saved to .blend fiel anyway. When you've got thousands of particles it affects on size dramatically.
But i would agree solving disk usage would need some complete fresh decision here.%%%
