Texture mapping for curves does not work correctly in Cycles.
Tested with Windows 64 bit
Blender v2.65 r53189
Texture mapping for curves does not work correctly in Cycles. The texture ends up "twisted" around the curve.
In the attached file try changing the renderer to Cycles and setting the material of the curve to "Cycles Material" and render. You can see in the node-editor it is set up precisely the same as the Blender Material, which is to be used with the Blender Internal renderer.
Brecht, can you please check on this report? Thank! :)
Fix in svn, thanks for the report.
Brecht Van Lommel (brecht) closed this task as "Resolved".Jan 10 2013, 6:37 PM
