Incorrect display normal-map on model with 2 UV's #33810
Reference: blender/blender#33810
Ubuntu 12.10
Tested on:
2.56 (from blender.org)
r53596 (ppa)
r53473 (ppa)
Even when UV-channel is set, normal-map displayed differently, while selecting different UV-sets in "Object Data"
%%%Same in render.%%%
%%%Seems tangent space calculation always uses active UV layer and think it's better be using render layer instead. At least for render it shall use it. Here's a patch which solve this.
Brecht, couple of questions:
%%%It is big problem for me, because I use other UV layer for coloring objects on particle system "Base_pero" using "From Dupli" method. So for normals needs one layer, for "From Dupli" - second one%%%
%%%Ideally multiple tangent spaces should be supported, but it indeed was not implemented. This patch would probably break quite a few existing files, better solution would be to implement this properly but at the moment not sure how difficult it would be.%%%
%%%Brecht, by "implement this properly" you mean add support of multiple tangent spaces?
I've looked into shadeinput and seems it first calculates tangent space and then applies all the textures. If it's indeed so afraid i'll need to rewrite some areas here :) If you think it worth doing i could spend time supporting this.%%%
%%%This is probably not so much difficult to support, but it requires quite a few of changes in BI renderer. I'll move the report to our TODO list (http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Render#Render_Engine) since it's not actual bug, but just a limitation of current system.%%%
