No shadow pass on Cycles from emission or environment lights
Mac OS X 10.8.2.
2.3 GHz Intel Core i7
NVIDIA GeForce GT 650M 1024 MB
r54535 (shadow pass results in all black for non-light illumination)
r54417M (it generates shadow pass correctly in this version)
On newer builds I cannot get a proper shadow pass for shadows cast by mesh (emission) lights or environment variable (HDR) lighting. This is both for CPU and GPU renders. It was working fine in previous versions (e.g. r54417). If there are no lights in the scene the shadow pass is completely black.
1. Create a plane and a cube with plain, white diffuse materials.
2. Create a plane with an emission material and position it above the other objects.
3. Set up two render layers, one for composite and one for shadow pass.
4. Render scene and connect a viewer to the shadow pass output in the compositor.
5. Black image is seen.
Interestingly, the AO pass does render correctly. As mentioned above, this happens regardless of the render device (CPU or GPU).
If there is a light in the scene then the shadow pass is rendered but it only shows the shadow cast by the light.
Could it be related to this closed bug #33984? (http://projects.blender.org/tracker/?func=detail&atid=498&aid=33984&group_id=9). Although that was apparently constrained to CUDA renders.
It's actually working as intended now, the shadow pass does not contain any shadow from the environment or emitting objects. As far as I know emitting objects were never included, and the environment only happened when multiple importance sampling / sample as lamp was enabled, which was a bug.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Archived.Feb 16 2013, 1:46 PM
Thanks for the clarification Brecht. That was a useful bug!
Without this, what is the recommended way of extracting shadow information for VFX compositing purposes when the only illumination in the scene is from an equirectangular HDR panorama?
A specific example is compositing an object over a camera tracked plate and casting realistic shadows. In other words, what is the proper way to make a shadow catcher material with cycles and environment lighting now?
I don't really have a recommendation for what to do in this case, I've added on my todo now an option to let the shadow pass include background lighting, but this will be for 2.67.
Hi Brecht,
I noticed that I can get a shadow pass again on 2.66a with only environment lighting. Is this a regression or is it expected now for shadow passes to work with environment lighting?
Will mesh lights never be included in the shadow pass? Or is that in the todo list? It would be useful. Thanks.
I am running Blender 2.67, but it looks like this did not make it into the project. Is it on plan for any future release? Thanks!
It's still on the todo list, but I don't know yet when it will be implemented.
Thanks, Brecht, for the update, I'll check back after 2.68 or later.
Brecht & Company:
I just want to quickly poke any developers on this issue. I'm surprised that the fix isn't requested more regularly, because it seems that virtually all compositing uses environmental lighting, and yet you always have to set up dummy lights for the shadows. So this issue is both (a) confusing when the user first runs into it and (b) compromises the realism of many composites.
Still, beggars can't be choosers, and I'm grateful for things as they exist right now. Thanks as always.
We need this feature (of "shadow catcher" or at least shadows for any emitters that bring shadows after objects). It's almost the base thing in most of 3d apps now.
I add myself to the queue. I'm slowly migrating from 3DS Max to Blender and in my projects I use a lot of these "shadow catchers" not just on regular planes but on more complex structures too. I use them to integrate 3D object into real pictures, not just panoramas. I was able to get something workable with compositing and rendering layers but it is a bit convoluted. A "shadow pass" working with emission material would be a good solution, even if a proper "shadow catcher" material would be preferable, especially considering all the camera tracking features that Blender seems to offer.
Kind regards,
Giovanni
Lack of possibility to get shadow pass taking into account emmissive meshes is pretty important. I tried to bake shadows on a plane in Cycles (just with camera) and finally I did it with point lights, but I had to spend very much time investigating the problem. It's really unobvious. Please implement what you said sometime. Thank you very much.
Does a "Closed, Invalid" status at the top, mean that this will never get fixed/added? - Thanks
No, it does not, just that this is not a bug.
Brecht, would you like me to open a related "To Do" subtask here in Maniphest to track this?
Thanks for the feedback, I was unaware of that Todo list :)
I think I see it in there (Woohoo!):
  • Option to include environment lighting in shadow pass.
Ah, OK. Just curious, how are those items usually prioritized?
And thanks for all your great work with Cycles and Blender. It's amazing how far along Cycles has come in such a short time and the beautiful things people are doing with it.
Looking forward to the things on that list in the future!
It seems to me that one could get the same result through compositing, having one layer "WithShadows", another layer "WithoutShadows" where the shadow-casting object does not belong, then using a subtract node in the compositor to isolate what the shadows have altered. Isn't it ?
I don't think so, the issue is that there is "no" shadows being created by environment lighting so whether you have a With Shadows layer or not, you'll get no shadows....without adding lights to simulate the environment shadows. Unless I am misunderstanding you.
Isaac Arias (ike) added a comment.EditedJul 29 2014, 8:42 PM
You can certainly do what PatB suggests (I've done it, I'll try to share a node tree here) but it requires creating additional render layers, etc. You don't get a Shadow Pass, you just render a Composite pass WITH shadows and "shadow catcher" object without, then subtract one from the other. You can then invert the resulting matte and use it as a shadow pass.
It would just be nicer and cleaner to have a Shadow Pass from the environment lighting. You can then just multiply the AO and Shadow passes onto the BG, under the object.
Thanks, I would like to see your node, and be interested to see how one would do as he is suggesting, without using any lights?
I edited the comment above to explain it briefly. I'll try to post a node graph screenshot when I get home tonight.
@Matt Outlaw (outlaw3d): note that the suggested compositing is not using the "shadow pass", just the regular image output. Subtracting image with shadows from image without shadows (actually without the objects that cast the shadows) has the effect that everything that was unchanged by shadows is cancelled out, leaving the shadows isolated.
This assumes that you can distinguish between the shadow-casting objects and the shadow-receiving objects, using separate layers. It is definitely just a workaround, not a long term solution.
I created the following example of shadow catcher using the compositor few months ago.
Open the blender file and press F12. It will generate all the layers including the shadow pass.
With some modification you can change the color of the shadows. Hope it helps.
Giovanni
Just popping by to see if any consideration of this had been made?
Does the development team still look at the Dev:2.6 Todo list (or is there a new one)?
http://wiki.blender.org/index.php/Dev:2.6/Source/Render/Cycles/ToDo
MacBook 2015 render by GPU and the same problem.
Hi,
I too would like to ask for the emission light in Cycles to contribute to the shadow pass. The current work around to subtract a "clean pass" from a "pass with shadows" will work but isn't ideal, as the intensity of the shadow will be dependent on the diffuse shading). For compositing over a wide range of plates, it would be better to have the shadows completely separated from the diffuse shading for max accuracy and range in compositing. It will also save on render time as I would not need to generate a clean pass. Thanks.
I landed here as I thought the shadow pass is buggy. It's black when I only have light emitters in my scene.
If you think the shadow pass works as expected Brecht, then maybe another shadow pass for light emitters would be worth adding.
