Category: Physics
It appears that if you set two character motion controllers on the same axis with opposite signs at the same time (ADD) it will sometimes result in an infinite vector for walk direction (and thus worldPosition). In the test file hold (W then S) or (S then W) or (A then D) (for some reason D then A doesn't do this).
Showing the console will show the outcome.
