I tried this file in several computers with the same result: crash , W7 and Linux
2.66 official release 64 bit
when this file has an output node connected in some of the channels it crashes, the channels usually are alpha, depth and UVs, maybe some others as well...
just hit the render button and you should see a crash, if it doesn´t crash please change the output folder manually into a different one and try again, it should crash.
This is a report from mfoxdogg using Linux:
http://www.pasteall.org/39922/
