Arch Linux 64-bit
Nvidia GTX 295
Error: Blender 2.66.0 r54697
Working: Blender 2.65 r53177
Normals can't be set using foreach_set in Blender 2.66. For example, something like this doesn't work anymore:
verts.foreach_set("normal", normal_list)
1. Open Blender and make sure default "Cube" is available.
2. Copy this code into the Text Editor (or open the attached Blend file):
import bpy
import random
verts = bpy.data.meshes["Cube"].vertices
for v in verts:
print(v.normal)
print('----------')
random_normals = [random.uniform(-1.0, 1.0) for i in range(0, 24)]
verts.foreach_set("normal", random_normals)
for v in verts:
print(v.normal)
3. Hit the "Run Script" button.
4. Verify that normals weren't updated in the console.
