Bunch of patches that allows Blender to display i18n monospace font in the text editor and the Python interactive console. Wide characters that occupy multiple columns such as CJK characters can be displayed correctly. Furthermore, wrapping, selection, suggestion, and cursor drawing should work.
Screenshot: https://plus.google.com/photos/108666457756457924138/albums/5847890778201826545/5847890782374975970?authkey=CIPZrc32pPzuTw
This patch uses wcwidth.c written by Markus Kuhn to estimate how many columns each character occupies:
http://www.cl.cam.ac.uk/~mgk25/ucs/wcwidth.c
wcwidth.c is distributed under MIT-style license:
Permission to use, copy, modify, and distribute this software
for any purpose and without fee is hereby granted. The author
disclaims all warranties with regard to this software.
I attached 3 files:
- texteditor_console_i18n.tar.gz ... Patch files (See below for details)
- texteditor_console_i18n.patch ... Same as .tar.gz file, but unified all patches into one file
- WenQuanYiMicroHeiMono.ttf.gz ... Font file for testing CJK characters display
The tgz archive texteditor_console_i18n.tar.gz contains 7 patches:
(0) 00_i18n_mono_font.patch
Patch to load i18n monospace font when "International Fonts" in user preference is ON.
Adds function to blenfont:
BLF_get_unifont_mono()
BLF_free_unifont_mono()
(1) 10_extern_wcwidth.patch
Integrates wcwidth.c into extern/wcwidth/ directory. I made wcwidth.h to use it as a library.
(2) 20_BLI_str_utf8_char_width.patch
Adds primitive functions to blenlib to use wcwidth.c:
BLI_wcwidth()
BLI_wcswidth()
BLI_str_utf8_char_width()
BLI_str_utf8_char_width_safe()
Also adds BLI_UTF8_WIDTH_MAX macro. Its value is 2 (in columns).
(3) 30_BLF_draw_mono.patch
Adds a function BLF_draw_mono() to blenfont. This is an analogue of BLF_draw() but drows texts with fixed column width. It takes additional the 4th argument 'cwidth', and returns how many columns were used.
(4) 40_BKE_txt_utf8_offset_to_column.patch
Adds functions txt_utf8_offset_to_column() and txt_utf8_column_to_offset() to blenkernel. They are alternatives of txt_utf8_offset_to_index() and txt_utf8_index_to_offset(), respectively.
Also modifies txt_move_up() and txt_move_down() to take character widths into account.
(5) 50_space_text_i18n.patch
Fixes the text editor (space_text) to take character widths into account.
Renames some internal functions to more suitable names:
txt_utf8_get_nth() -> txt_utf8_forward_columns()
text_pixel_x_to_index() -> text_pixel_x_to_column()
flatten_len() -> flatten_width()
flatten_index_to_offset() -> flatten_column_to_offset()
Also changes args/retval of some inernal functions.
(6) 60_space_console_i18n.patch
Fixes the interactive console (space_console + space_info) to take character widths into account.
Adds internal functions to compute offsets for wrapping:
console_wrap_offsets()
console_cursor_wrap_offset()
To build blender with the patch, apply the above 7 patches or texteditor_console_i18n.patch, and save the font file into release/datafiles/fonts/ directory.
Note 1: WenQuanYi Micro Hei font is used only for testing. We should prepare more appropriate one, because the WQY font doesn't include all languages' characters which Blender supports. If you want to test the patch with the other font, save it as "WenQuanYiMicroHeiMono.ttf.gz" (file name is hard-coded). For example, to use DejaVu Sans Mono font on Ubuntu,
gzip -c9 /usr/share/fonts/truetype/ttf-dejavu/DejaVuSansMono.ttf > [PATH_TO_SOURCE_TREE]/release/datafiles/fonts/WenQuanYiMicroHeiMono.ttf.gz
Note 2: I'm testing it only on Ubuntu 12.10 (with both CMake and SCons), not tested on Win/Mac at all.
texteditor_console_i18n_v2.tar.gz
texteditor_console_i18n_v2.patch
Minor change. In console_cursor_wrap_offset(), use BLI_str_utf8_char_width_safe() rather than BLI_str_utf8_char_width().
texteditor_console_i18n_v3.tar.gz
texteditor_console_i18n_v3.patch
Minor optimization.
Can anyone test/review this patch?
texteditor_console_i18n_v4.tar.gz
texteditor_console_i18n_v4.patch
bmonofont-i18n.ttf.gz
bmonofont-i18n-licenses.tar.gz
Update for code cleanup r55123.
Also replace "WenQuanYiMicroHeiMono.ttf.gz" with "bmonofont-i18n.ttf.gz".
bmonofont-i18n.ttf is a mixed font based on DejaVu Sans Mono and including M+1M Regular and Wen Quan Yi Micro Hei.
Versions and licenses of the included fonts are as follows:
DejaVu Sans Mono: version 2.33, Bitstream font license and Arev font license and public domain
M+1M Regular: TESTFLIGHT 54, M+ font license
Wen Quan Yi Micro Hei: version 0.2.0-beta, GPLv3 with font embedding exception or Apache2.0
See license files in bmonofont-i18n-licenses.tar.gz for the details.
Checked the patch, looks good to me.
Suggest Shinsuke Irie be given commit rights to commit this patch.
OK, I'll commit the patch. Please give me commit rights.
However I'm not sure where the license docs of the font should be stored. I couldn't find license docs of droidsans.ttf.gz.
Looked over the patch. Looks fine to me as well. Just one note which isn't directly related on this patch. Would be nice to get rid of casting int<->wchar. it's possible that they're different size on different platform. Better to avoid this :) (for sure could be done as separate patch later).
