Weird noise bug with Texture nodes
Win7 64 Nvidia gtx
2.66
There is an interesting bug with texture nodes. it creates a noisy look to the nodes in use. I thought that it was a Cycles related issue however it can be repeated with the internal as well so it must be independent from the renderer. I am not sure how to describe this issue, I think best is to check the screenshot and the sample scene attached. When you open the scene make sure you are viewing the compositing nodes
Load the attached scene, press render. And make sure to check the attached screenshot.
You are using a texture node tree, as a texture in the compositor.
That is giving thread issues.
Maybe someone might give this a try, or we should find a way to disallow it?
Fixed in svn rev55021. Thanks for the report, closing.
Sergey Sharybin (sergey) changed the task status from Unknown Status to Resolved.Mar 4 2013, 2:15 PM
